6 Pages <1234>»
Mark's DC-3 Options
mwstratton
#21 Posted : 05 March 2019 10:53:47
Thanks for all the kind words. I'm pleased with the results so far. I was afraid that my fingers were too big and dumb for all the tiny bits.BigGrin BigGrin LOL
Pack 2 should be here next week.
Under the Bench:
#22 Posted : 05 March 2019 14:49:35
BigGrin That cockpit looks the biz Mark Love
Keep up the good work ThumpUp
Gray
mwstratton
#23 Posted : 15 March 2019 23:14:52
Pack 2
Pack 2 has arrived. This session I will build the right side of the crew compartment.
Hope you enjoy watching as much as i am in the build.
mwstratton attached the following image(s):
Under the Bench:
mwstratton
#24 Posted : 16 March 2019 04:20:30
Pack 2
In This session I I built the right side of the crew compartment.
This kit is a lot of fun
Under the Bench:
#25 Posted : 16 March 2019 08:30:38
That`s looking very tidy. Cool Cool
Don`t know if you have, but now is a good time to check how well the two sides of the crew compartment match up and come together before you add the detail.
Keep up the good work. BigGrin
mwstratton
#26 Posted : 16 March 2019 10:10:21
Thanks for the tip derek. The fit between the 2 sides and the floor is spot on.
Under the Bench:
mwstratton
#27 Posted : 16 March 2019 11:52:56
Pack 2
During this session I tackled the first of the Avionics and other compartment details. I also created the carpet and fitted and glued the floor.
Thanks for stopping by
Under the Bench:
#28 Posted : 16 March 2019 21:57:38
Looking very nice Mark.Love
mwstratton
#29 Posted : 16 March 2019 22:26:40
Thanks Mark
Under the Bench:
#30 Posted : 17 March 2019 09:18:05
Hi Mark,
Very keen on watching this build come together ,also neat tidy and clean no a spot of glue.
Trev.
mwstratton
#31 Posted : 17 March 2019 12:17:56
tf64 wrote:
Hi Mark,
Trev.
Thanks Trev. Glue is not my mess of choice. It's painting of PE parts Cursing as you will see when I post my next update.
Under the Bench:
mwstratton
#32 Posted : 17 March 2019 12:23:39
Pack 2
During this session I finished the avionics and details in the left half of the crew compartment.
I have found my weakness Cursing, that is painting of photo etched parts. It always looks messy. Next paint stage I am going to slow WAY down and give more dry time between coats of paint, especially between the primer and first color coat.
At least the messy bits are not in full view in the completed model.Blink
Seats are next
Under the Bench:
mwstratton
#33 Posted : 18 March 2019 18:53:10
Pack 2
This session I concentrated on the crew seats.
I had my first major screw up. While bending the PE seat frames I didn't pay close enough attention the the direction of the flanges that attached the seats to the side supports. Top fix this I had to grind out openings on the othe side of the seat support to allow room to attach the seat backs.
A special note, when gluing the seat back halves together, make sure to clean out the glue from the notches for head rest attachment.
Other than that, this was a good session.
Come back soon
Under the Bench:
#34 Posted : 18 March 2019 23:57:00
It`s looking good and you will get lots more practice with the seats and etch later in the build to perfect your skills. Like you said, take your time and when painting the etch try a practice piece first like the scrap from the etch frame.
Try a light sanding with 1000 grade wet and dry first and then thin coats of paint with good amount of drying time.
Keep up the good work and if you need some help/advise just ask.
mwstratton
#35 Posted : 19 March 2019 03:10:58
Thanks Derek
Under the Bench:
mwstratton
#36 Posted : 19 March 2019 03:29:28
Pack 2
This session I finished the interior of the crew compartment and then glued the 2 halves together. No problems were encountered.
Next I start skinning the exterior.
See you next time.
Under the Bench:
#37 Posted : 19 March 2019 07:37:04
Hi Mark,
Regarding painting Photo Etched parts, I was wondering if you have tried air brushing as this will give the finish you are looking for.
Trev.
#38 Posted : 19 March 2019 08:53:02
Hi Mark, you are certainly cracking on with this build, looking excellent.
mwstratton
#39 Posted : 19 March 2019 09:56:05
tf64 wrote:
Hi Mark,
Trev.
I have Trev. Problem there is I have a cheap airbrush that likes to spit paint so it overcoats small parts. I really need to invest in a better one.
Thanks for the input.
Under the Bench:
mwstratton
#40 Posted : 19 March 2019 09:57:10
Thanks Mark
Under the Bench:
6 Pages <1234>»
This page was generated in 0.525 seconds.
