MRH fault after fault after fault Options
MRH
#1 Posted : 28 February 2019 13:48:33
Rank: Newbie
Well, here goes, on finishing the build it didn't work, batteries are good, no loose connections so change MCU......
MCU changed & jumps forward on start-up & flashes red, that's all it will do so then change power board....
Great, everything works except head motor travels at light speed in both directions with a thump so order a replacement head motor......
Head motor replaced & low & behold, doesn't work at all on the batpack but on plugging in AC charger, head motor works as it should but no "chirp" & just flashes pinkish, anyone else had this cascade of problems, will strip again & test batbox connections but cannot see that is the problem as all I have done is change head motor, not impressed Cursing
#2 Posted : 28 February 2019 16:08:24
When you have finished checking the cables and battery connections,do the start up proceedure again as you have change both the mcu and power boards.
Also check that the cables are fitted home tight and the correct way around.
Hope you get it sorted, keep me updated.
