13 Pages 123>»
Micks 1/200 battleship bismarck Options
#1 Posted : 26 February 2019 15:42:03
Hi decided I will do diary on this one so here we go issue 1
Foredeck and glue various parts to it, nice and simple, no fit issues on mine, and good quality parts,
Issue 2 the foremost twin 38cm gun referred to as Anton as German ships named there guns fore to aft as there German radio alphabet so second gun would be Bruno or Berta, third Caser, fourth Dora and so on went together well no issues at all. That's it for now, look forward to me next parts, cheers mick.BigGrin
#2 Posted : 26 February 2019 15:48:48
ooh another Bismark build.I have a question. I assume the parts are prepainted? If so I wonder how they are going to hide the seams between the hull parts.
#3 Posted : 26 February 2019 16:17:58
BigGrin Hi Mick,
Glad you decided to do a build diary ThumpUp As you say, all's gone together easily so far and your build is looking good.
Have you looked into upgrade kits yet? I had a browse on Ebay but nothing jumped out as being able to fit. Was hoping for metal barrels Sad
Anyway, keep up the good work and will be following with interest.
Gray
#4 Posted : 26 February 2019 17:29:59
Hi for what I see of hull seams they overlap so the seams will be seen ,as to if that's right or not ,time will tell as get more hull parts ,think the outer barrels of guns are ally anyway they felt to heavy to be plastic.think going to have to get lot more of this yet ,before can decide on extra detail yet ,cheers mick.BigGrin
#5 Posted : 26 February 2019 17:46:19
Great to see your progress MickBigGrin enjoy your build.
#6 Posted : 26 February 2019 18:01:18
Great another build to follow MickBigGrin looks goodDrool regards PhilCool
#7 Posted : 26 February 2019 22:15:25
BigGrin looking good mickCool
#8 Posted : 27 February 2019 07:02:51
BigGrin Nice start and looking goodCool
#9 Posted : 30 March 2019 14:18:58
Hi thanks to all who looked in and left comments much appreciated
On we go issue 3
Attach the below waterline bit of Hull to bow section from issue 1,fits perfectly, then it build up the first plane arado ar 196 pleasure to build up, all fitted perfect, just make sure you get the struts on the floats all the right way round.the plane is plastic,but all the struts, and catapult launch carriage are metal, strength where needed, cheers mick.
#10 Posted : 30 March 2019 14:23:44
BigGrin Lovely update Mick, always good when the parts fit together well ThumpUp
Those little planes look good too
Regards Gray
#11 Posted : 30 March 2019 14:26:23
Issue 4
Here we attach a fixing to the next bit of Hull, then start on the catapults,one is shown on-board, and one extended for launch,the top bit is metal,the bottom plastic,again fit is perfect,then we get to test the recoil on the first gun,mine works well, does say you will here salvo in instructions, but as no sound board bin provided yet, it won't,cheers mick.
#12 Posted : 30 March 2019 14:30:41
Issue 5
Again we start attaching a fixing to opposite side of Hull part, same as before, then fit the chain guides and covers to the Foredeck, then build up the capstans,cheers mick.
#13 Posted : 30 March 2019 14:35:48
Issue 6
Simple one this just attach the next bit of below the waterline,to the hull,perfect fit again,and color match,I test fitted the top bit done previously, fitted perfect,this hull is going to be heavy when complete, that's me up to date now,eagerly await me next parts, cheers mick.
#14 Posted : 30 March 2019 17:29:15
Looking good Mick
Cool Cool Cool
#15 Posted : 30 March 2019 19:46:41
BigGrin All looking good Mick and nice workCool
#16 Posted : 30 March 2019 22:39:26
Progressing nicely Mick, all looking good....Cool Cool
#17 Posted : 02 April 2019 16:47:03
Nice progress Mick!
#18 Posted : 04 May 2019 14:12:16
Issue 7
Here we just make a start on the anchor gearbox,and put together the anchors. All fitting well. Cheers mick BigGrin
#19 Posted : 04 May 2019 14:17:20
Issue 8
Put another plate on the hull.and attach this to Hull we already got. And add few more details to Foredeck.
#20 Posted : 04 May 2019 14:25:18
Issue 9
Here we finish the anchor gearbox and fix it under the Foredeck put the capstans on, and the small capstan head from issue 1 thread the chains through and attach the anchors. Though it don't say in instructions, I tested mine will only work one way, till get more electrics on it. Mine works well cheers mick
13 Pages 123>»
