HMS Surprise available as Subscription or Full kit Options
#1 Posted : 23 February 2019 20:05:25
Get your HMS Surprise in 12/24 monthly instalments or Full kit.
Key Features of the HMS Surprise:
Laser cut keel and all main frame parts, High-quality planking mahogany, walnut and lime woods.
High-quality fittings in white metal burnished or in real die-cast brass.
Stitched sail set and rigging threads.
Pre-finished high-quality display base with name plate.
Overall Dimensions
Scale: 1:48 | Length: 1334 mm (52.75") | Height: 950 mm (37.5") | Beam: 480 mm (18.5")
https://www.model-space....d-the-hms-surprise.html
Also available from the Modelspace store is this practical set of basic ship modelling tools from Artesania Latina at an additional cost.
This tool kit includes:
Nº1 modelling knife, Pin-nailer, Archimedes mini-drill, Side cutter pliers, Snip Scissors and Sanding block:
https://www.model-space....-modelling-toolbox.html
Also Keep your tools and consumables in perfect order with the modellers workstation, it has many compartments and drawers to keep your tools and parts together.
https://www.model-space....elling-workstation.html
Also the Paints & Tools Organiser is the perfect compliment to the Modellers Workstation:
https://www.model-space....nd-tools-organizer.html
(modelling items not included)
This page was generated in 0.141 seconds.
