80 Pages «<3435363738>»
#701 Posted : 22 February 2019 09:44:47
That concludes this weeks update [GandaleFlapper].
Thanks for looking in, have a great weekend and happy modelling.
Phil W.BigGrin
#702 Posted : 22 February 2019 12:33:55
Looking good Phil. a lot of love and attention to detail in your build. Cool BigGrin Drool Drool Drool
#703 Posted : 22 February 2019 13:54:01
Thank you very much Ian!Cool BigGrin Due to it being 1/48 scale, I have nowhere to hide when it comes to detailing. A smaller scale such as 1/72 for example, you can get away with not including every single item, but not in 1/48! I personally love adding all the small details to give it that 'fine-scale' feel.
#704 Posted : 22 February 2019 20:54:40
Nice work Phil, those rivets are going to look good.
#705 Posted : 22 February 2019 23:33:45
Top notch work Phil, absolutely riveting....LOL LOL Drool Drool Drool ..
#706 Posted : 23 February 2019 08:24:14
BigGrin All looking good Phil and nice additionsDrool Drool Cool
#707 Posted : 23 February 2019 13:09:08
Outstanding as always Phil BigGrin will you be building up the kits enginesConfused regards PhilCool
#708 Posted : 23 February 2019 17:56:08
Great scratchbuilding Phil,this has to be the most detailed example of this kit anywhere.
#709 Posted : 25 February 2019 10:47:07
Thank you Mark! The rivets will be used to secure all the valve hand-wheels on the guns and also on the pipework.
#710 Posted : 25 February 2019 10:48:09
Thank you Alan. A bit more progress in the right direction!
#711 Posted : 25 February 2019 10:52:29
Cheers Andy! Looking forward to detailing the guns with the after-market additions.
#712 Posted : 25 February 2019 10:58:09
Hi Phil, yes, will be building the diesel engines as per the part-works instructions. They are pretty well detailed as they stand, so I can't foresee myself adding much more to these apart from the odd pressure gauge here and there. Getting to the point where i'll be working on them though is still a long way off yet, so stay tuned for when i do.
#713 Posted : 25 February 2019 11:03:51
Hi Al, I'm pretty confident that this will be the only 1/48 scale model of a U-boat with a later style conning tower in the world!Cool
There's plenty of U-boats in this scale with the older style conning tower, including the Hachette U96 and Trumpeter U552, but none with the modified conning tower, so it will be a very unique model. I'm hoping I can get it displayed at the Royal Navy Submarine Museum when done.
#714 Posted : 25 February 2019 11:50:52
I think they would be honoured to have her, when you run out of extra details to put on her and get her finished LOL
#715 Posted : 25 February 2019 16:40:06
LOL Al. Only a few extra details to go on this wee beastie!FlapperBlink
#716 Posted : 28 February 2019 22:43:14
This weeks update sees the completion of the two water-tight ammunition canisters that are located on the upper deck of the conning tower.
After making the locking bars and grab handles last week, it was now time to scratch build the hinges. For these I used 0.8mm half-round plastic strip for the hinge brackets and 0.5mm diameter rod to form the hinge pins. All very fiddly I have to say!Blink
#717 Posted : 28 February 2019 22:44:59
Completed hinges from another angle.
#718 Posted : 28 February 2019 22:48:39
The next job was to fabricate locating strips that will support the surrounds that encircle the canisters.
The locating strips were made from 1.5mm half-round strip. Four lengths were cut to 8.5mm in length for the larger of the canisters and four lengths cut to 1.0mm in length for the smaller one. They were all glued with PVA so I had time to position them correctly.
#719 Posted : 28 February 2019 22:49:49
From another angle.
#720 Posted : 28 February 2019 23:00:56
The next stage was to make the surrounds. A bit of trial and error [faffing about] ensued before i settled on a technique.
I used 0.25mm thick plastic sheet and cut two strips; one 8.5mm wide for the larger canister and the other 1.0mm wide for the smaller. By wrapping each strip around a piece of 11.0mm diameter tube leftover from when i made the larger canisters on the lower deck, i could cut each strip until their ends just met. I then cut two smaller strips to act as fasteners for each piece and glued these over the join of each strip while they were wrapped around the tubing. I then carefully slid them off, checked them for fit around their respective canisters and then fixed in place with PVA. There is a slight excess of PVA that can be seen in the attached photo on the smaller canister, but I will clean this up prior to painting.
Guest (8)
This page was generated in 0.306 seconds.
