R2d2 not working correctly Options
Scherry
#1 Posted : 18 February 2019 11:46:12
Rank: Newbie
Please help my r2 is not working correctly, after receiving a replacement Mcu and put back together this is what it is doing
Switched the model on
It jumps forward
Green LED is solid Red LED is really faint
Head rotates at expected pace
Head roates back to the front Red LED still faint but the projector is on showing Luke on repeat but no blue LED
Lightsaber will not move up or down.
Any ideas?
#2 Posted : 18 February 2019 12:47:50
Has a check been done on the spec of battery you have, do you have a supplier link for the battery purchased just to be sure?
Scherry
#3 Posted : 18 February 2019 12:52:38
Rank: Newbie
Batterys have been checked and all are fine have unplugged and replugged all cables and made sure they are all the way home and now have not a clue what to do
#4 Posted : 18 February 2019 14:40:12
Initially it sounds like an incorrect battery spec or connectivity problem, such as incorrect wiring, bent socket pins, connector plug not properly seated or an inverted connection.
"Inverted connection” seems to be the most common cause of a malfunction.
An inverted connection means that the connector has been plugged into the correct socket but is the wrong way round. Which once power is connected, can cause damage to the MCU and other components at the same time, such as the various motors and circuit boards.
We've been informed by a number of customers of a battery being correct that transpired to be incorrect once a supply link was provided. We just need to be certain of the battery spec so we can rule this out, can you therefore provide a link to the battery purchased.
Thereafter, a careful check needs to be done of the connectors & wiring.
Scherry
#5 Posted : 18 February 2019 17:35:43
Rank: Newbie
Thank you for the informative reply I have checked the wiring again and found a small tear in one of the wires and have patched it up and now works fine.
#6 Posted : 18 February 2019 17:44:04
That's good to hear and enjoy your R2 Cool
