80 Pages «<3334353637>»
#681 Posted : 15 February 2019 00:55:11
This photo shows the brass barrels alongside my 3d printed 3.7cm gun.
#682 Posted : 15 February 2019 00:56:36
That concludes this weeks update and last weeks 'faffing about'.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#683 Posted : 15 February 2019 08:55:10
Nice update Phil, we all have weeks of faffing about.LOL
Love the brass gun barrels.Love
#684 Posted : 15 February 2019 16:05:25
Thank you Mark. I honestly thought that making the canisters would be less challenging than some of the things I've made for this boat. But no! lol
The brass barrels look good don't they. Will fit that one next week and then look at the gun as a whole. Maybe replace some of the valve hand wheels with etched brass ones. Due to 3d printing, the gun feels very fragile, so I'm going to strengthen it by substituting some details for plastic or brass.
#685 Posted : 15 February 2019 20:28:45
Drool You're setting the bar awfully high for those of us who have yet to even start ours BigGrin
#686 Posted : 15 February 2019 20:50:30
BigGrin There are some nice upgrades out there and looking goodCool
#687 Posted : 15 February 2019 23:36:28
Your tenacity and abundant patience have certainly paid off and even though you spent time faffing about I'm sure now you think it was all worth while, especially with the results you've ended up with..BigGrin BigGrin Excellent work as usual Phil......Drool Drool
Do try not to faff about this week otherwise we'll have to wait longer for your next update.....LOL LOL
#688 Posted : 19 February 2019 13:34:13
Don't be put off Gray. I hope that my 'faffing about' proves that sometimes things don't always work out first time around.
#689 Posted : 19 February 2019 13:35:27
Thanks very much Andy! Yes, there are some nice upgrades out there, just takes awhile to locate the suppliers that's all.BigGrin
#690 Posted : 19 February 2019 13:40:42
Thanks Alan!Flapper LOL Negative faffing this week!
Not all the ideas I have work out first time round, but I'm glad i got it resolved and it shows members how I arrived at the end result.
#691 Posted : 21 February 2019 23:17:02
Good to hear Phil... now where's your update....LOL LOL Flapper LOL LOL
#692 Posted : 22 February 2019 09:24:33
This week i started making the two water-tight ammunition canisters for the upper deck. They are smaller in diameter than those for the lower deck with added extra detail.
I used 9.5mm diameter plastic tube, bought as a 1 meter length, for the main body of the canisters as seen in the photograph.
#693 Posted : 22 February 2019 09:27:43
From this tube i cut two small lengths; one 2mm and the other 10mm to form the main body of the canisters. I then cut four plastic discs using the compass cutter from 0.25mm thick plastic sheet and topped and tailed the tubing with these to form cylinders as seen in the attached photo.
When the glue was dry, I filed the edges of the discs flush to the tubing.
#694 Posted : 22 February 2019 09:29:36
Using 2.0mm diameter plastic rod, i cut two 1.0mm lengths and fixed these to the top of each cylinder.
#695 Posted : 22 February 2019 09:31:40
The next step was to cover the top of the cylinders with Polyfilla and let it dry overnight. Once dry, i filed a taper from the top of the cylinders down to the edges.
#696 Posted : 22 February 2019 09:33:40
The next step was to fabricate the locking bars that hold the top of the canisters down. For this i started by using 1.0mm square strip, cut two pieces to 2.0mm in length and fixed to the centre of each cylinder.
#697 Posted : 22 February 2019 09:36:26
Using the 1.0mm square strip, i continued this down from the centre, leaving a slight overhang so i could file flush to the body. To make the catches i fixed 1.0mm x 0.5mm strip, cut to suit and glued to the ends of the 1.0mm square strip.
#698 Posted : 22 February 2019 09:38:46
The next step was to make two handles for the cylinder tops from 0.5mm diameter brass rod.
0.55mm diameter holes were drilled into the tops of the cylinders and the brass rod bent to shape.
#699 Posted : 22 February 2019 09:41:04
I have a little more work to do on these water-tight ammunition canisters; fitting hinges and making a surround for each. i'll cover these steps in next weeks update.
Meanwhile i took delivery of the brass gun barrels for the 2.0cm guns that will locate on the upper deck. PB Models of Poland is the supplier.
#700 Posted : 22 February 2019 09:43:25
I also ordered and took delivery of some very small rivets, 0.5mm diameter and 3.0mm long from Prime Miniatures [UK].Blink I will be using these to fix hand-wheels to the guns and later for the valve hand-wheels when i start to detail the inside of the U-boat.
Guest (6)
This page was generated in 0.434 seconds.
