Thunderbird 2 Extension Pack - Official Build page 3 Options
#1 Posted : 07 February 2019 18:42:49
Stage 91
Pod 2 Crane Frame
Parts Supplied:
Crane top plate, Main frames L+R, Subframe 1, Subframes 2, Struts, Corner plates, Number plates, Crane shafts and screws.
Fit one of the corner plates into the corner of the crane top plate and fix in place with two screws from the opposite side of the crane top plate. Then install the rest of the corner plates in the same way.
Glue one of the struts in place by inserting the pins into the corresponding holes in the top plate and then fit the other three struts in the same way.
Note: Subframe 1 has two small holes through it, also note that subframe 1 and subframes 2 have inner and outer sides. Assemble them so that the flat sides of the claws at both ends are on the outside.
Holding the main frame R, insert the end of subframe 1 into the upper hole with the inner side facing away from you. Then insert a subframe 2 into the hole at the bottom of main frame R, below subframe 1. Now making sure you have the correct orientation fit the remaining subframes 2 to the rear holes of mainframe R.
Position the four ends of the subframes into the corresponding holes in main frame L. Now turn the assembly on its side so that main frame L is on the table and carefully push the ends of the subframes into the holes.
Pass one of the crane shafts into a hole in a main frame and secure the shaft in place with one of the shaft screws. Then fit the other shafts in place and secure with screws in the same way.
Glue a number plate to the two holes in a main frame and then fit the second plate to the same position on the other side of the assembly.
Mobile Command Centre
Parts Supplied:
Cockpit, Windshield, Body, Body bottom, Headlights, Antennas, Console and Seat.
Glue the body and body bottom together.
Remove the seat and console from their fret and glue the seat into the cockpit. Then glue the console into the cockpit in front of the seat. Now without using glue fit the windshield to the cockpit and glue the cockpit to the body.
Remove the headlights from their fret and glue them into the holes at the front of the cockpit.
To finish the mobile command centre, remove the two antennas from their fret and glue them into the holes in the top of the body.
Stage Complete, carefully store any remaining parts in a stage labelled bag.
#2 Posted : 07 February 2019 22:46:20
Stage 92
Pod 2 Crane
Parts Supplied:
Shaft cover, Shaft unit 1 - 3, Top plates 1, Top plates 2 - 4, Top plates 5 - 8 (on a fret), Magnet, Shaft.
Retrieve the crane top plate from stage 91 and glue the shaft cover over the centre of the crane top plate. Turn the top plate over and glue a top plate part 1 into place, followed by the remaining three parts 1.
Glue top plate parts 2 and 3 together and then glue top plate part 4 into the other end of part 2. Now glue top plate part 5 into the hole in part 4. Make a second assembly by gluing top plate part 8 into top plate part 6.
Press the magnet into the top of shaft unit 1, noting that the magnet will protrude slightly from the top of the unit. Glue shaft unit 3 onto the top of shaft unit 1 to retain the magnet and glue shaft unit 2 into the base of shaft unit 1 making sure it fully engages into the slots.
Now pass the wide end of the shaft up the centre of shaft unit 1 until it engages the magnet. Then insert the thin end of the shaft into the hole in the centre of the crane top plate and glue unit 1 to the top plate making sure that the notch is engaged to get the correct orientation of the parts. Check now that the shaft can slide in and out to test its movement.
Glue the larger assembly from earlier onto the top plate followed by the smaller one and then finally glue top plate part 7 to the top plate, noting that it has a D shaped hole to fit into, so you get the correct orientation of the part.
Explosive Tractor
Parts Supplied:
Wheels A (on a fret), Wheels B (on a fret), Front wheels (on a fret), Chassis, Tracks, Axles, Front tracks (outer), Front tracks (inner), Front tracks.
Remove the drive wheel parts A and parts B from their fret and carefully remove any burrs. To make the drive wheels glue each drive wheel A into a drive wheel B. Now make the six sets of wheels from the A and B parts in the same way.
Insert one of the axles into a drive wheel and the other three axles into three of the other wheels. Identify the front and rear of the chassis and feed the drive wheel/axle through the rear hole in the chassis. Retain the axle in place by pressing the other drive wheel onto the free end of the axle. Now repeat this action for the other three axles and then pull the tracks over the wheels on both sides from the drive wheel end.
Carefully separate the front wheels from their sprue and trim any burrs. Now fit four front wheels to a front outer track without glue and then carefully glue a front inner track onto the outer and fit a front track. Now repeat to make a second unit.
#3 Posted : 08 February 2019 13:06:38
Stage 93
Pod 2 Crane
Parts Supplied:
Top plate parts 9 - 26
Glue top plate part 21 in place on the crane top plate followed by part 22. Then glue part 18 next to part 22. Now glue part 15 to 16 and glue part 17 into the top of the assembly. Then glue the completed assembly to the top plate. Parts 19 and 20 can now be glued around the previous assembly.
Glue part 26 to the top plate. Now glue top plate parts 24 and 25 to part 23 and fix the final assembly to the top plate.
Glue part 10 to the top plate and glue part 9 next to part 10. Next glue part 13 to part 10 and part 14 to part 9. Now glue part 11 (marked L) to the side of part 13 and part 12 (marked R) to the other side of 13.
Retrieve the crane frame. Now making sure you have the correct orientation insert the four shafts into the holes in the corners of the top plate and push the plate up to the top of the frame. Now take the frame and glue the pins in the corners of the frame into the holes in the pod floor and insert the ends of the shafts into the holes just in from these.
Explosive Tractor
Parts Supplied:
Cockpit, Cockpit rear, Main body, Bulkhead, Front track guards, Tail lights, Battery covers, Head lights - Air intake - Front grille on a fret, Front and rear handrails on a fret, Screws.
Insert the front grille into the central hole in the main body and fix the right and left headlights to either side of the grille. Then push the air intake into the slot below the front grille.
Glue the cockpit rear into the main body and then glue the cockpit into position on the main body. Next glue the front handrails to the rear of the cockpit and the side of the main body making sure the handrails are in line on each side.
Glue the bulkhead to the main body just behind the cockpit and then glue the rear handrails to the bulkhead and main body making sure they are aligned with each other. Next glue one of the battery covers into the slot in the main body and repeat on the other side of the body with the second cover. Now glue the tail lights into the two holes in the rear of the main body.
Take one of the front track assemblies from Stage 92, press it into place and secure it with one of the two screws. Using the same method fix the second track on the other side. Noting that the front track guards are labelled 'L' and 'R' glue them onto their relevant tracks.
#4 Posted : 09 February 2019 11:59:46
Stage 94
Pod 2 Base
Parts Supplied:
Front base panel, Rear base panel, Hatch halves x2, Screw hole covers X8, Gangway, Nameplate, Ladder, Tensioners X4, Screws.
Glue the gangway to the front of the crane frame and then glue the ladder to the gangway and the holes in the floor below.
Retrieve the seven pod frames from stage 83. Noting that each frame has its own numbered slot fit frame 1 into its slot in the pod floor and secure the frame with a screw. Now fit frame 2 to the slot behind it in the same way. Gently spread frame 3 and engage it with the slots on either side of the floor and secure it with two screws. Carry on and secure frames 4, 5 and 6 to the floor in the same way. Now fit frame 7 fully into the slots in the centre of frames 1– 6 and then engage the front and rear of frame 7 with the pod walls.
Combine the front and rear base panels and secure them together with two screws.
Slide one of the tensioners into each side of both the hatch halves. Then place the hatch halves into the base panel making sure they fit flush to the panel. Place the pod assembly onto the base panel and align it to the posts. Now tighten a screw into each of the aligned holes in the floor to secure the pod to the base.
Glue the name plate to the inside of frames 2 and 3 and then glue the eight screw hole covers into the holes in the pod floor.
Explosive Tractor
Parts Supplied:
Motor, Carrier upper, Carrier lower, Searchlights (on fret), Mirrors (on fret), Box, Nameplate, Launchers X18, Dampers X2, Side plates X2, Side rails (on fret), Antenna X2.
Fit the two dampers to the carrier upper. Then pass the dampers into the slots in the carrier lower and press the hinges of the two carriers together.
Insert the posts of the chassis into the holes in the underside of the body. Then glue the motor to the main body and the box to the top of the motor. Next glue the post on the underside of the carrier into the hole in the body.
Fit the side plates and the side rails to each side of the main body. Next glue four of the red launchers onto the front four carrier posts, eight yellow launchers onto the middle eight posts and the remaining four red launchers onto the last four posts.
Glue a mirror to either side of the cockpit. Then glue the searchlights into the top of the cockpit, followed by the name plate. To complete the Explosive Tractor, glue the two antennas into place.
#5 Posted : 10 February 2019 12:00:12
Stage 95
Pod 2 Roof and Display Stand
Parts Supplied:
Roof panel outer, Roof panel inner, Roof panel clear, Crane sides, Crane centre, Crane arms, Arm ends X4, Cylinders X4 (on fret), Metal buttons X4, Screws, Virgil Tracey, Thick stand frames, Thin stand frames, Stand frame columns.
Glue one of the metal buttons into each of the arm ends and then snap the end of each arm into the arm ends. Next insert a cylinder into the end of an arm and turn the cylinders by 90 degrees to click it into place. Gently squeeze the end of the arm to ensure the parts are properly fitted and repeat for the other three cylinders.
Now fit the end of one of the cylinders into the centre of one of the crane sides and turn the cylinder by 90 degrees to engage the 'T' with the slots in the crane side. Then push the arm between the ends of the crane side and test that the arm can swing in and out. Using the same method fit a second arm to the crane side and then prepare the second crane side.
Open the hatch on the underside of the pod and pull the main shaft out fully. Insert one of the screws through the hole in the middle of the crane centre. Then holding the crane centre onto the end of the shaft secure it there with the screw. Now glue one of the crane sides onto each end of the crane centre. When the glue has set, push the crane into the pod and push the top plate all the way to the top of the frame so it is held by the magnets. Now close the hatch.
Glue the roof panel outer to the inner and press the parts together until the glue sets. The roof will sit neatly onto the space between the two side panels. Pod 2 is now complete. With this stage you receive a clear roof panel which you can use instead of the standard one.
Carefully remove the cockpit windscreen and fit the Virgil Tracy figure into the pilot seat in the Thunderbird 2 cockpit, then replace the windscreen.
Insert one of the thick stand frames into one of the stand frame columns and the insert another thick stand frame into the holes at the other end of the column. Now fit a column onto the other end of the stand frames. Then repeat the procedure to create a second frame.
Insert the four thin stand frames into the columns of one of the frames made previously and insert the free ends of the thin stand frames into the other frame. The stand is now complete and will allow you to display the pod with the crane out. The thicker frames are slightly longer, so position the pod with these at the side. The metal buttons at the end of the crane arms will be able to hold the explosive tractor.
Carefully lower Thunderbird 2 over the pod.
This completes the build of the Thunderbird 2 Extension Pack.
This page was generated in 0.291 seconds.
