Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,867 Points: 20,918 Location: Northamptonshire, England
Does look an excellent kit, nice work Trev Mark Regards Markwarren (Mark) Admin
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Thanks for looking in Mark,more soon. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice to see some more progress with this one Trev, looking good mate and looking forward to your next update. Well done.
Kev  Per Ardua Ad Astra
Thanks Kev for looking in and your comments. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
You're doing a really nice job of this Trev. Top work! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Phil,thank you for taking the time to view my work, I am finding this a very rewarding kit to build and excellent value for money,more to follow. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi all, time for an update, today I fitted the wall this had to be sanded be for fitting.The wall forms part of the coach structure, the first job was to moisten the area to be curved then ensure that it was well centered, then start to glue on the upper part of one of the side beams, I then left for 24 hours, if all goes well when dry and the glue has set, using a modelling saw or cutter trim off all the surplus. Have a look.    Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice update, certainly cracking on with it. Mark Regards Markwarren (Mark) Admin
Very neat and tidy work as usual Trev, all looking good.... Regards Alan
Nicely done Trev, looks good.
Hi,Mark,Alan,and Spal I thank you all for looking in,and your comments the next part will be lining the interior and floor,could be tricky keep looking. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Yes indeed Trev, nice tidy work and looking good, very well done.
 progressing nicely Trev. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Kev: Lined the inside and started to place the battens on the front side of the box,I think it is to give a bulging effect,this will be made from 2x4 basswood you need a fast setting glue as you have to stand them on there side,more pictures soon. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks for looking Ian,I have worked more on the front side and will be posting pictures soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Trev
Interesting stuff Trev and a great insight into the techniques you are using for building this model, well done.
I'll look forward to your next update with bated breath!
Lining the interior and floor of the box. First I cut several pieces of 150mm of 0.6x30mm from sheet to line the interior part of the curved wall and then cut several pieces of different sizes to line the interior of the side beams and floor. Next I cut four pieces to line the interior corners using a steel rule to cut the strips,glued in place and sanded down with fine paper.  Placing the battens on the side beams of the box on its exterior part. This is to give the box a bulging effect by gluing different size pieces of 2x5mm basswood on there sides and sanding down to the edges.   Thanks for looking Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
This is looking very nice indeed Trev, going to be stunning when finished.....  .. Very well done.... Regards Alan
Very nice work Trev, this is going to look superb when its done.
Thanks Alan and Daran, starting to get a feel for this model, it is like all the kits I have from De/Ago not only do you have to learn how to build them but you gain experience,plus you teach yourself it's history which stays with you. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
