Joined: 08/09/2015 Posts: 27 Points: 74 Location: Mudgee, NSW, Australia
Hi All, Can someone please measure the display case (wooden base dimensions and 'glass' sides) that come with the subscription? I am looking at making a custom one and am interested in what size the original case is. I plan to have a mirrored base (so you can see under the car) and have the car mounted on two supports. As well as perhaps having the doors open too.
Peter
6 months later and I assume no one has the display case (judging by a couple of threads) or haven't got around to measuring it. I am still interested in the dimensions and even a photo of it in the case to see how much room there is around the car (IE can it be displayed with the doors, bonnet and boot open?).
 Don't know if this helps, as i didn't realise this came with a case as part of the subscription. I was going to say that the display case on sale would fit (but not very attractive is it). https://www.model-space....lay-case-modelcars.html
Car dimensions: Length: 590mm (23.2”) | Height: 170mm (6.7”) | Width: 230mm (9”) Display Case dimensions: Length 634 mm, Height 220 mm, Depth/width 294 mm Cheers Gray
