Very nicely done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks for your nice comments, guys!Greetings, Walter
Just a small update:
I finished the last two yards for the spritsails as well as the boomkins. Also i added footropes to the jibboom and flying jibboom.
So i finally achieved my goal to complete all the partwork until the end of this year - and i`ll be able to start the new one with the rigging.
Happy new year to everybody!DaDokta attached the following image(s): Greetings, Walter
 Lovely work Walter  and a happy new year Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Nicely done and hope the goggle eyes dont affect you too much when doing the rigging Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking forward to seeing this continue, Walter. Happy new year to you also.
May be a small update but a very nice one at that Walter.... Rigging, now the fun begins.... Regards Alan
Nicely done Walter  look forward to seeing your progress in the new year with the rigging. Al
Thanks for your nice comments!
In the meantime i added all the Pendants (also the topmast ones).DaDokta attached the following image(s): Greetings, Walter
Then i attached the shrouds to the foremast - but when experimenting with how to add the deadeyes - the mast kept turning around.
So i decided to secure the masts to the hull a little bit earlier than suggested in the instructions.
This way i think i could achieve a straight alignment and upright Position of all the masts easier than after attaching all the shroudsDaDokta attached the following image(s): Greetings, Walter
As a little extra detail i added another mast socket to the mizzen mast at the quarter deck level (was quite fiddly to get it in the right position).DaDokta attached the following image(s): Greetings, Walter
Looking very good Walter. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Ian!
This is just so you guys don`t think i`m lazy. But although i spent many hours with my Vic one can´t see much progress!
So here are some pics of my shrouds with all the attached deadeyes.DaDokta attached the following image(s): Greetings, Walter
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Walter, Looking good. Glad to see some pics. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Looking great Walter, very soon you'll be onto the dreaded ratlines..... Regards Alan
Thanks Garth , Alan!
Next step was adding the deadeyes to the masttops. But here i had a problem - as when applying Tension the deadeyes tended to turn and go between the little steps we built on the masttops.
So i came up with this solution:
I added a little wood strip and drilled the holes for the shrouds.DaDokta attached the following image(s): Greetings, Walter
Now i could thread all the shrouds through those new holes and through the ones we previously drilled into the masttops.
This assured that all the deadeyes are now sitting firmly at the same height and direction.
Maybe this helps if anyone has a similar problem.DaDokta attached the following image(s): Greetings, Walter
Hi guys! I finally attached all the shrouds (including the topgallant shrouds) to the three masts.DaDokta attached the following image(s): Greetings, Walter
Before moving on i added a few blocks to some of the the eyebolts on the deck, as i want to add lashings to the stays instead of just binding them to the bolts.
I think i will now start producing all the gunport-lids - which i`m not looking forward to!!DaDokta attached the following image(s): Greetings, Walter
Progress is progress Walter and good to see you're moving forward... All looks great.... Regards Alam
Guest (15)
