raginbill Options
Raginbill
#1 Posted : 04 February 2019 22:45:21
Rank: Newbie
Hello. Is anyone else having problems with R2 spinning it’s head from violently from stop to stop when moving forward when being controlled by the app? Or shoulder sensors not working when in patrol mode?
Hope someone can help.
Thanks.
#2 Posted : 04 February 2019 23:34:33
On start up is his head movement as per the start up procedure head goes from side to side and he beeps as it comes back to the centre.
What exactly is happening when your R2's sensors are not working for example is it when using the app or in autominous mode.
Raginbill
#3 Posted : 05 February 2019 11:05:59
Rank: Newbie
Yes, the head does what it should do on start up. It’s only when holding the forward command on the joystick type controls on the left. If I use the one touch commands on the right, the head is fine and doesn’t move.
Also, if I choose patrol mode through the app the sensors don’t work but if use the buttons on the body, they work fine.
#4 Posted : 05 February 2019 13:45:10
Possibly your finger control on the screen is inadvertently touching 3 commands at the same time?
When you control R2 manually, his sensors are switched off to make it easier to carry out tight manoeuvres. Have you downloaded a copy of the online R2 User Guide which this point is noted: https://www.model-space..../download/file_id/4316/
This page was generated in 0.081 seconds.
