R2D2 stoppoed working Options
Leight
#1 Posted : 02 February 2019 13:44:49
Rank: Newbie
Hi, R2 was working fine on first start up. All functions worked and app connected fine.
However when I turned if off and turned back on it now no longer powers up when you press the front button. I plugged it in to recharge but noticed that no lights came on to indicate charge status. I have recharged the batteries and all at full charge.
Anybody know the issue could be or what might need to be replaced if it is an infant mortally issue with one of the circuit boards?
#2 Posted : 02 February 2019 14:33:27
Double check all your connections as something may have worked loose.
Could you also provide a link to the batterys you have bought.
This page was generated in 0.082 seconds.
