12 Pages <1234>»
Soliel Royal by Mark Options
mwstratton
#21 Posted : 01 February 2019 00:49:18
Pack 2 - Stage 6
Hey guys welcome back to my build.
This stage came together nicely.
I'll be back...
mwstratton attached the following image(s):
Under the Bench:
#22 Posted : 01 February 2019 00:54:34
I do like the care and attention you appear to be applying to this Mark, some very neat and tidy work being shown.... Very well done....Cool Cool
mwstratton
#23 Posted : 01 February 2019 00:57:45
I tend to be quite meticulous almost to the point of OCD
Under the Bench:
mwstratton
#24 Posted : 01 February 2019 07:11:42
Stage 7
This stage was also without incident. I built a jig for cutting deck planks to length of 70mm. Made the process much quicker.
I sealed the deck with 4 coats of Minwax polycrylic satin clear coat.
Under the Bench:
mwstratton
#25 Posted : 01 February 2019 08:18:12
Stage 8
Well another stage down with no problems. This kit is a dream to build so far.
The bulkhead on frame 4 was sealed with clear coat now for convenience.
Under the Bench:
mwstratton
#26 Posted : 01 February 2019 08:19:49
mwstratton wrote:
Stage 8
LOL Forgot to post pics
Under the Bench:
#27 Posted : 01 February 2019 08:57:17
Coming on very nicely.
#28 Posted : 01 February 2019 09:02:56
Excellent work Mark. Your doing a nice clean tidy job and great build log.
#29 Posted : 01 February 2019 13:36:27
Fantastic build so far!
#30 Posted : 01 February 2019 14:24:27
Well done Mark. Enjoying your build ThumpUp
mwstratton
#31 Posted : 02 February 2019 09:17:39
Well I spoke too soon. Shortly after starting Stage 9, I discovered the slight twist in the very forward false keel I found and thought I fixed in Stage 1, has reared it's ugly head.
While fitting the upper deck I noticed that frames 2 and three were slightly out of line, more so on the starboard side. I was able to trim the notches and get the deck to fit.
In Stage 10 I found more evidence that the keel is in fact got a slight starboard twist. It looks like the hole for the bowsprit will need modification. I need to figure out the easiest way to do that.
Any suggestions?
Under the Bench:
mwstratton
#32 Posted : 02 February 2019 09:21:45
Here is the rest of the Stage 9 pics
Under the Bench:
#33 Posted : 02 February 2019 11:25:42
Hi Mark,
Doing well on your build.
The ribs are not a problem you could have just pulled them into the notches on the deck. They would not of changed anything on the shape of anything for you. You normally get the odd tip of ribs twist a little, the cutouts on the decks are usually correct.
As for the bow and false keel. It doesn't look too bad. I would need picture of head on and one one directly down over it. Here is the official build pic to show you.
mwstratton
#34 Posted : 02 February 2019 16:29:41
magpie1832 wrote:
Hi Mark,
Here are more detailed pics of the issues at the bow. Not overly concerned about any twist in the ribs as they can be faired. My question really is about making sure the hole for the bowsprit is true. would hate to get to that stage and find that the bowsprit wont fit.
Under the Bench:
#35 Posted : 02 February 2019 16:39:16
You can see there is a little twist from the front where the notch is cut out. The best way would be to un-glue from the deck and re clamp it in line with the deck cutout at the front, then re glue. The formers each side of it should sit better then. As for the hole ,it is drilled out at a later stage to fit the mast there so not such a problem.
mwstratton
#36 Posted : 02 February 2019 17:23:12
Thanks Chris
Under the Bench:
mwstratton
#37 Posted : 03 February 2019 02:52:16
Pack 2 Stage 10
This Stage finishes the stern end of the false keel. The Bowsprit deck was also planked.
Under the Bench:
mwstratton
#38 Posted : 03 February 2019 02:55:17
Pack 2 Stage 11
Added the next rib section and Bow formers.
Under the Bench:
mwstratton
#39 Posted : 03 February 2019 02:57:07
Pack 2 Stage 12
Under the Bench:
#40 Posted : 03 February 2019 09:18:57
All looking good Mark, lovely work.....Cool Cool .. Making good progress there....
12 Pages <1234>»
This page was generated in 0.442 seconds.
