MCU changed - Head still spins fast Options
SeanC
#1 Posted : 29 January 2019 12:15:11
Hi guys,
I'm hoping someone in here has a solution to my R2D2 not working properly. I've stripped the droid down at least 4 times now and checked/ double checked that every plug and wire is correctly labeled/ installed. I initially put it down to a faulty MCU so I ordered a new one and have fitted it but it's still doing the same. Everything else seems to work except for the head motor
Does anyone have any other suggestions as this issue is really starting to get me down. I've been very methodical during the build, checking my work at every stage and it's such a disappointment when this is the end result.
I've attached a video link to show the problem.
https://youtu.be/NUCgv7QhVnQ
Thanks in advance,
Sean
#2 Posted : 29 January 2019 12:33:08
Hi Sean
You may want to request a new head motor from c/s.
SeanC
#3 Posted : 29 January 2019 12:42:38
Thanks Mark, I'll look out my issues and find which issue the head motor was delivered with. I hope this fixes it
Best regards, Sean
#4 Posted : 29 January 2019 14:08:15
Hi Sean
It is in Issue 96.
SeanC
#5 Posted : 29 January 2019 14:10:26
Thanks Mark, I've called CS and reordered issue 96. I really hope this solves the problem
Best regards,
Sean
