Still doesnt work Options
Koah
#1 Posted : 26 January 2019 21:33:12
I have got the batteries i was told to get on my last topic but he still wont turn on and im starting to get frustrated. iv checked the connections
#2 Posted : 26 January 2019 21:53:54
Hi Could you explain exactly what is or is not happening on start up and have you followed the start up instructions to the letter.
Also if you can borrow a voltage meter can you check the leed from the battery box to check what voltage you are getting from it.
Koah
#3 Posted : 26 January 2019 21:57:58
He won't switch on at all and iv followed all the instructions. I shall try check everything again. Is there anyway to for someone to come check him
#4 Posted : 26 January 2019 22:03:16
Firstly can you check that your getting power from the battery box by using a multimeter to test the voltage.
Koah
#5 Posted : 28 January 2019 19:03:51
I did see that someone could come out to check him but i cant find the post as next monday pm would work well for me
#6 Posted : 28 January 2019 19:13:10
There is no such post on the forum as it’s not a facility that’s available.
Koah
#7 Posted : 28 January 2019 19:16:21
Ah okey thank you
#8 Posted : 28 January 2019 19:54:51
Can I ask which batterys you finally settled on and did you follow the correct start up procedure and have you downloaded the online full user guide.
Koah
#9 Posted : 28 January 2019 19:56:55
Yes i got the batteries from the link that was posted and followed the start up procedure. I will check all the connections again
#10 Posted : 28 January 2019 20:03:45
Could you check the voltage coming from the Batery box leed and below is a link to the downloadable user guide-
https://forum.model-spac...aspx?g=posts&t=30359
Koah
#11 Posted : 28 January 2019 20:06:04
Thank you I will do when I get a chance to :)
