Victory X-Section - Frame Fragility Query? Options
oledad
#1 Posted : 27 January 2019 11:26:20
Rank: Beginner Level 3
Mellow I want to start this build by Mid Feb. In reviewing build diary it appears in the beginning the 8 rib frames are pretty fragile until one gets the hull planked. Ant tips as to how to prevent this other than just being extra careful. Also what do you consider the best wood glue and superglue to use? Did not know if an thing new over the last two years.
Thans, Oledad
#2 Posted : 27 January 2019 12:01:44
Hi Oledad,
Yes the ribs are a little fragile but you do get a brace to put at the top of the ribs to help. Other than that its just to take extra care with them.
The glues , wood glue best is Aliphatic wood glue which is strong and is stainable if you go down the natural route.
https://www.cornwallmode...l-P5524821.html#SID=478
Super glue can be any but I just use this one and have never had any problems with it and its cheap. (they do thick and thin too)
https://www.amazon.co.uk...GP-STICK2/dp/B00W22F716
This page was generated in 0.087 seconds.
