R2-D2 start-up issues Options
zx7red
#1 Posted : 26 January 2019 13:12:23
Got the batteries from amazon and they work fine however when turning r2 on his head continuously turns to the right until I turn it off again. already checked all the connections but lost as to what to do now as I want him working
Built so far R2D2 building Samba T1 and loads of lego
#2 Posted : 26 January 2019 14:49:06
Hi could you provide a link to the batterys you bought please.
zx7red
#3 Posted : 26 January 2019 17:27:34
bought 8 of these https://www.amazon.co.uk/LG-Indu...18650+button+top+battery
Bit expensive I know but needs mustBigGrin
#4 Posted : 26 January 2019 17:53:56
Hi those look like nib tops with a vent in them can you double check they are making a good contact with the plus end of the battery box.
zx7red
#5 Posted : 26 January 2019 18:13:13
they are the button top batteries, photo's don;t do them justice and I am getting a good contact top and bottom of the individual cells getting 3.74VDC from each cell
#6 Posted : 26 January 2019 18:59:23
Can you recheck the conections from the head motor to the MCU you may have a pin pushing one of the wires out and not making a good contact.
semaj
#7 Posted : 26 January 2019 20:21:43
3.7v is low charge. When full charge they will read 4.2v. 3.7v per cell is not enough to power our droid.
Building:
Complete:
zx7red
#8 Posted : 26 January 2019 21:27:21
I'll check the pins and get my mulimeter out to recheck the batteries voltage
#9 Posted : 26 January 2019 22:00:20
You should be getting 12.3 volts aprox from the end of the battery box cable when tested.
zx7red
#10 Posted : 27 January 2019 18:18:30
right, we have some progress, getting 12.37 VDC from the battery lead and when I lift his head off the motor and pass a screwdriver through the head sensor his head motor stops turning and I have managed to connect the wifi. when I replace the head and look from underneath the metal part sticking down from the head support is passing through the sensor but the head keeps turning onto the stopsCursing
zx7red
#11 Posted : 27 January 2019 18:31:18
Forgot to add as I have got all the covers off, have rechecked all connections and all seem good and tight, no bent pins or loose wires
#12 Posted : 27 January 2019 18:40:19
Order a replacement head motor from C/S.
zx7red
#13 Posted : 27 January 2019 19:10:27
will do Thanks for your helpBigGrin
zx7red
#14 Posted : 28 February 2019 15:56:52
Got the new head motor today but still not working, head now spins rapidly round one way and thumps on the stops but head motor is still trying to turnCursing , Also getting a red led light on the head. Have rechecked the connections for the head sensors as well as the head motor and all seems good
#15 Posted : 28 February 2019 20:12:54
You may have a duff head sensor order a replacement issue 83. Also can you double check all your connections.
SeanC
#16 Posted : 28 February 2019 21:40:12
I have the exact same issue. I've replaced the MCU and head motor and it still won't work. Surely the tech team/ designers of this model should know what the fault is. Ordering parts is now getting tiring.
I've emailed Modelspace and attached this link (https://www.youtube.com/watch?v=z92ZMwZjFes) to the video of how it operates. Hopefully this time I will get a reply as I'm still waiting on a reply to my initial email in December!
Sean
SeanC
#17 Posted : 28 February 2019 21:45:45
Just to add, if it's the head sensor that's faulty then how does this cause the head to spin fast? Surely there is something causing the motor to drive fast. My batteries are the correct button top ones which I purchased from 18650.uk
Best regards,
Sean
#18 Posted : 28 February 2019 22:05:44
Hi Sean
Can you create your own thread on your R2 please so we dont get conflicting advice.
Also have you double checked all your tabs are correctly added to each wire as per the instructions and that each plug is placed the correct way round in all the sockets.
SeanC
#19 Posted : 02 March 2019 00:53:39
arpurchase wrote:
Hi Sean
Hi Andy, my problem is exactly the same as this chaps so what's the point in starting an identical thread? I've checked and double checked every tab/ connection etc (several times) and everything checks out.
My main concern is the lack of support from model space. They are happy to take your cash but the impression I get is they don't give a hoot when things go wrong. Surely the boffins who designed this model will have an idea what could be wrong with it. The most disappointing thing is they simply don't seem to care, the customer service agents really are clueless and have no idea what your talking about when you call them and they fail to reply to emails
The model was completed in December and we are now in to March and it still doesn't work. I'd be more than happy to post this piece of junk back to them for a full refund but the chances of that happening will be zero!
Best regards,
Sean
#20 Posted : 02 March 2019 09:00:31
Can you describe what is happening to your R2 in a new thread please or it will be harder to help you.
You also need to understand that I am trying to help you and that if you have a problem with C/S give them a call and ask to talk to a supervisor to resolve your issue.
