Joined: 08/01/2015 Posts: 68 Points: 178 Location: Holland
Many thanks Boys, its good to be back at the bench out of the cold On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
rigging cutty sark is a great job. and you do well - well done
Good to see you got the hang of photos, nice work
Hi Shipmates Taking a break from Rigging  and started to fix the sails to the Yard-arm. Not bad with a needle and thread Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Looks good Terry, very neat and tidy needlework there.... Regards Alan
jep , that look great
As a beginner to modeling I have referenced the manuals and find very difficult to follow so I have made my own methods of doing things. Please look at the photos and let me know what you think and offer advice if possible. 1. Attach rigging to Clump Block 2. Using a clamp set the Clump Blocks at the required distance 3. Coat the yarn with glue turning it into a needle 4. Connect the Blocks together with the yarn 5. Complete by tying go the loose ends I hope this is of interest to you all Thanks. Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Well Shipmate Now I understand the meaning of "learning the ropes".  all the Rigging is complete together with the Stays and Bracing now to raise the sails Onwards and upwards Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
All looking good Terry, very nice work.... Regards Alan
Morning Modelers Started on some of the sails  She's beginning to look like a Boat Cheers. Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Looks amazing Terry. They look good when half rigged but like you say as soon as sails start being fitted they transform in to a proper ship. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking very nice. You are definitely a dab hand at that now. Mark Regards Markwarren (Mark) Admin
Always good to see the sails and rigging finally being added. She's looking fab Terry, well done..... Regards Alan
it looks good and you are well on your way with the rig, it is a pleasure to see.
Hi Shipmate Been working on the Fore Mast Sails, So many ropes need four hands Have a good weekend Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
 Wow, it's going to look amazing in full sail
Looking very impressive Terry. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work, very impressive. Mark Regards Markwarren (Mark) Admin
Rigging one of these ships can be very challenging but the trick is simply to take your time with it. You're certainly doing a great job so far, she's looking amazing.....  .. Very well done.... Regards Alan
Morning Shipmates Next set of sails are prepared now to hoist them up. hope you're all well Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
