Accurate Armours 1/35 Ward LaFrance M1A1 Wrecker. Options
#1 Posted : 15 January 2019 19:31:54
BigGrin Hi All
This is a full resin kit from Accurate Armour of the standard WW2 wrecker used by the alies. As a full detail kit it has the engine and all the drive shafts for the crane and wheel drives and consists of 200 plus parts in the kit including resin,etch, chain brass rod and wire there is also a full set of stowage items in the kit along with decals.
The kit is in AA's card box and protected with bubble wrap, on opening the box you see the instructions and the parts below it made from grey resin. All the parts are crisply moulded but as with all resin kits will need some fettling to get the best out of them. Most impresive was the single chassis casting.
The instructions are well detailed and have both pictures and a write up for each stage along with deployed and traveling crane modes.
A very nice kit with loads of detail that also has lots of characterDrool Drool .
#2 Posted : 16 January 2019 17:55:42
That looks a cheeky kit with a lot of detail Cool
#3 Posted : 16 January 2019 18:02:47
Very nice looking kit, with some steady hands and careful clean up it will build into a very detailed kit.Cool
#4 Posted : 17 January 2019 21:21:42
BigGrin Thanks for looking in and your comments both, it's very detailed and not easy to see from the picturesCool
#5 Posted : 18 January 2019 09:58:59
Nice looking kit, should be an interesting build. AA do make highly detailed, quality resin kits, the extra work required with resin is usually well forth it.
#6 Posted : 18 January 2019 22:31:17
BigGrin Thanks for looking in Greame and your comments The Wife also treated me to couple more AA kits as an Xmas prezzy tooDrool Drool Drool Cool
#7 Posted : 26 January 2019 00:12:56
BigGrin Looks like this may be going towards a red ball express recovery dio with the latest additionsDrool Drool Drool Cool
#8 Posted : 26 January 2019 00:29:34
That will be a cool dio Cool
