Still does not work Options
Koah
#1 Posted : 16 January 2019 18:32:45
My R2D2 still does not work. I got the correct batteries. Is it possible to get someone to look at it or pick it up to check as this has cost alot of money and i want to hear him beeping along.
#2 Posted : 16 January 2019 18:49:57
Can you show a picture of your batterys and provide a link to where you bought them from please . Also what exactly is wrong with your R2.
Koah
#3 Posted : 16 January 2019 18:59:41
Hi here's the batteries https://www.ebay.co.uk/i...87?txnId=2005941299011. He won't turn on at all and I charged the batteries before.
#4 Posted : 16 January 2019 19:58:05
I strongly suspect that your batterys are not powerfull enough to run R2 the continuous output amps being the culprit here. Many people have had good results using the battery in the link below-
https://18650.uk/product/samsung-30q-button-top/
Koah
#5 Posted : 16 January 2019 20:01:33
I thought they was the same batteries
#6 Posted : 16 January 2019 20:13:12
Check the spec of the batterys in the link compared to yours, its the continuous discharge rate you should be looking at the ones in the link are-
Discharge: 15A Max Continuous
The ideal max continuos discharge for R2 would be around 8 to 10 amps or higher.
Koah
#7 Posted : 16 January 2019 20:27:18
Here is the battery info i cant work them out
Specification:
Brand: PKCELL
Voltage: 3.7V
Storage Voltage: 3.7-3.9V
Charging Cut-off Voltage: 4.2V
Discharge Cut-off Voltage: 3.0V
Capacity: 2600mAh (NOT HIGH DRAIN)
Weight: 46g
Protected: NO
Battery top: Button top
Max Constant Charging Current: 2200mA(1C)
Max Constant Discharging Current: 4400mA(2C)
Material: Lithium Li-ion ICR
Recharging cycles: At least 500cycles
#8 Posted : 16 January 2019 20:40:59
If you scroll down further is also says-
This is not 30A high drain type! This is 2C standard type.
So your batterys are around 3 amp max continuous discharge which is not powerfull enough to run R2.
A high drain battery or the ones I showed you in the link is better suited to the operation of R2.
Koah
#9 Posted : 16 January 2019 20:42:17
doh ok. If i got these batteries would they be ok?
Genuine Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery For Doorbell
Specification:
Product Name: Samsung INR18650-30Q 3000mAh Unprotected Button Top
Brand: Samsung
Model: 18650
Nominal voltage: 3.6V
Discharge cut-off voltage: 2.5V
Nominal discharge capacity: 3000mAh
Discharge: 2.5V
Charging mode: CC-CV, 4.20 ± 0.05 V, 100mA cut-off
Charging time: Standard charge : 180 min / 1500mA Rapid charge: 60 min / 4A
Max. continuous discharge: 20A
Cell weight: 48.0g
Cell dimension: 64.85 ± 0.15mm(H)X18.33 ± 0.07mm(D)
#10 Posted : 16 January 2019 20:56:59
You could try the ones in the link below-
https://www.ecoluxshopdi...00mah-15a-button-battery
Koah
#11 Posted : 16 January 2019 21:01:55
#12 Posted : 16 January 2019 21:16:25
No I would not recommend buying any batterys from any online auction site as you could be buying fakes. All the genuine Q30 batterys I have seen are 15 amp so your 1st link with 20 amps tells me they may be dodgy.
The links I have provided above are what forum members have used to power there R2's with successful results.
Koah
#13 Posted : 16 January 2019 21:19:02
Okey I shall get some of them and hope he works
Koah
#14 Posted : 16 January 2019 21:24:41
This one's not from auction site but to check they the same batteries
https://techdelivered.co...jasyoEGIjShoCKDsQAvD_BwE
#15 Posted : 16 January 2019 21:32:53
There flat tops not button tops.
Koah
#16 Posted : 16 January 2019 21:33:54
Opps ok I make sure i get right ones
This page was generated in 0.114 seconds.
