r2d2 startup problems Options
frank könig
#1 Posted : 12 January 2019 21:44:43
Hello I have a problem, my r2d2 does not start. I did everything as described in the instructions. When I press the start button lights only the square colored lamp behind the Dom. Otherwise, nothing happens. i have samsung 18650 mha 3500 butten top batteries trill
#2 Posted : 13 January 2019 00:03:10
Can you post a link to the actual batteries you have purchased?
frank könig
#3 Posted : 13 January 2019 00:34:48
Samsung INR18650-35E 3.6V - 3.7V 3500mAh Li-ion Button Top Single Cell 18650
Detail:
increased positive pole (button-top)
Size 18650 d 18mm l 65mm
Voltage 3.6-3.7V Capacity 3500mAh
Discharge current approx. 10A
Weight about 49g
unprotected without protective circuit, care should be taken not to discharge the cells below 2.75V
Strong reading mark cell especially for Ebike and much more.
Liion batteries should only be charged with a suitable charger under supervision. The voltage must never rise above 4.2V and below 2.75V when discharged.
According to manufacturer specifications, these batteries may only be used with a suitable
Protective circuit operated. Observe the specifications in the data sheet of the manufacturer. We assume no guarantee or liability for improper handling of Liion battery cells.
#4 Posted : 13 January 2019 09:45:13
Hi Frank can you borrow a voltage meter and check the voltage across the batterys in the box and at the end of the battery box cable.
frank könig
#5 Posted : 13 January 2019 10:17:23
Good morning purchase, I have no voltage tester and do not know where you can borrow this. Greeting Frank
#6 Posted : 13 January 2019 10:52:37
Hi Frank, if you cant borrow one then there are severall on e-bay at a reasonable price-
https://www.ebay.co.uk/s...multimeter&_sacat=0
Or replace the battery box though its difficult to determine if the box is at fault without a power check.
frank könig
#7 Posted : 13 January 2019 20:38:25
Thank you for the reply purchase, my wife asks on her job the electrician on a voltage tester. regards Frank
Levelord
#8 Posted : 13 January 2019 20:53:17
Groups: Registered, Moderator
Hi Frank, ich schreib mal auf deutsch der Einfachheit wegen 😉
Du musst vor dem ersten Start das Akkupack „aktivieren“ dazu musst du die bereits geladenen Akkus in R2 montiert haben und das gelieferte Netzkabel von issue 100 ca 1min anstecken zum Laden an R2 😉
Ich hoffe das hilft dir.
Lg Sascha
Der gesamte Baubericht und alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung. © Levelord
@work: X-Wing,Dodge Charger, MIG-29
Completed: McLaren MP4-23, Hummer H1, RedBull RB7, Easy Rider Bike, Jaguar E-Type, Porsche 911, Ferrari F2004, AMG DTM Mercedes, Ford Mustang, R2-D2, C57, Modellbahn,Rossi Bike,VW Käfer 1303,VW T1 Samba Bus
frank könig
#9 Posted : 13 January 2019 22:02:59
Danke für die antwort Sascha, ich habe die akkus alle seperat mit dem akkuprüfgerät voll aufgeladen. Dann habe ich sie in r2d2 getahen, das netzteil reingesteckt und ein paar secunden gewartet. Dann habe ich den anknopf gedrükt. Das ergebnis wahr er hat nichts gemacht. Das einzigste was geht ist die hintere bunte eckige leuchte funktioniert so lange ich den an knopf gedrückt hallte. Gruß Frank
frank könig
#10 Posted : 13 January 2019 22:04:38
Thanks for the answer Sascha, I have the batteries fully charged separately with the battery tester. Then I saw them in r2d2, plugged in the power supply and waited a few seconds. Then I pressed the button. The result is true he did not do anything. The only thing that is possible is the back square light works as long as I kept the button echoed. Greeting Frank
frank könig attached the following image(s):
#11 Posted : 13 January 2019 23:38:17
Could you provide a picture of the button top end of your battery please.
