 Rank: Pro Groups: Registered
Joined: 29/12/2018 Posts: 223 Points: 671 Location: Lancashire
Im wondering if its easier to build the entire false keel before i add the ribs!!!! Reason im asking if i build the false keel then i can attach it to a jig and from there..... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Hi Ant My recommendation would be to build as per the instructions, the official build and the official video build. Once you have glued the frames to the keel then you can set the whole assembly into the build jig. Official Build and video build follow the instructions very closely and highlight potential problems you may come across during the build. Link for the Official Build https://forum.model-spac...topics&f=17&p=2
Link for the Video Build https://www.youtube.com/...pjUDnPzoDagw3u2T7tQIBv4
Regards Alan
Well i finally got started today and gave it 2 1/2 hrs dont time fly.... Any way ive done the ribs etc. A light sand over the joints and ive stuck them together with gorilla wood glue i had left over from a few mths ago..... I will try n add pics later.. Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Hi Ant Glad to see you're up and running Your right, the time does fly when having fun A word of caution though - be careful with the Gorilla Glue! I used it on my Trinny build. Had a problem, which needed to be dismantalled, and the glue set like concrete. I would advise Aliphatic Glue. Same grab, but any problems you can at least get it to come apart with hot water! Here is a link that you may find interesting: https://www.model-space.....1540462758.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=112847303 Regards Gray
Downloaded an app for my note 8 to resize so lets see... Below is what i managed to do i two n half hours on the false keel and the ribs.. Non of the ribs are fixed at all...... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Decided to start the launch today as for the next few days im a tad busy so ive freed up time to concentrate upon the launch.. Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Great start Ant look forward to seeing your progress. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Had a bit of time spare so i glued in the launch ribs.... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Great to see your pics Ant and it looks like you're off to a very nice start, all neat and tidy. On the launch, be very careful when it come to fairing and the frames, they are very delicate and easily broken....  .. Look forward to seeing your next update.... Regards Alan
Great start, looks like you've got right into it. Mark Regards Markwarren (Mark) Admin
 Well done Ant  , looks like your really getting the hang of this, and enjoying your build to boot Keep it up Regards Gray
Only problem so far is the one the part 3 supports on the launch.. The one on the photo is extremely loose... So i need to somehow keep it in place... I have had two thoughts. One is to try and put a slither into the joint where it attaches or just a tiny spot of superglue on the outer edge to hold it... Or I could sand the edge of piece 3 and slot it back in after to plank it.. Any other ideas that may help.... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Ant62 wrote:Only problem so far is the one the part 3 supports on the launch.. The one on the photo is extremely loose... So i need to somehow keep it in place...
Any other ideas that may help.... Hi Ant, The two #3 formers are temporary formers to aid with the planking of the hull. You can glue the formers to the build jig but not to the frame. You can apply a little glue to the small tab at the base of #3 that fits into the frame. This should be enough to hold the formers in place. Also, when planking ensure you do not glue any planks to these #3 formers. You can sand the edges of the formers as part of the fairing process then glue them to the jig when done, just take care you don't take off too much material when doing so, check often... When you come to separate the launch from the jig these two formers should simply fall away from the assembly. Hope this helps. Regards Alan
Cheers for that... I will glue them to the jig later.. There is no mention of this in the instructions...... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Ant62 wrote:Cheers for that... I will glue them to the jig later.. There is no mention of this in the instructions...... It shows this in steps 6 & 7 of the instructions and it is mentioned in the Official Build Diary for Stage 6. The official build follows the instructions very closely and gives additional pointers and tips to assist you.... https://forum.model-spac....aspx?g=posts&t=729
Regards Alan
I had a spare hrs to kill this morning so i started on the launch planking.. Mmmmmm.. Never done anything remotely close to planking before so this is my first attempt... 1hr ended up turning into 3hrs overall.... I have some priming and filling to do i think i did ok.... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
 Very nicely done Ant looking forward to seeing your your next update Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Primed.. Filled. Primed. Filled. Base coat.. Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
I got into the painting of the launch exterior yesterday.. I had some acrylic paints from the plane i built with my nephew spare so though why not.. Noticed i kept the boat on the jig for easier handling when painting.. Still requires a few coates though.. Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Looks like you're making good progress Ant, look forward to seeing more.... Have just sent you a PM... Regards Alan
