Projector Lights up but no video Options
Deredeo
#1 Posted : 11 January 2019 13:45:25
Rank: Newbie
The rest of the functions seem to work fine so far but when I use the projector I get a beam of light and the voice over for Leia or Luke in full, however the picture is missing. I do get a circle of light but no image of any kind, I've taken it apart and double checked the cabling and that seems to be fine.
Any ideas guys?
PeterP
#2 Posted : 11 January 2019 16:18:35
Did you test the projector after you assembled it? sounds like you may probably need a new projector display screen and circuit board from issues 27 contact C/S the number is on the inside of the cover
Bobbaf3nn
#3 Posted : 11 January 2019 16:52:22
Good luck getting a replacement issue 27 .. When i requested one deag advised out of stock
Probably selfish people requesting them first time around to get spares or thinking it was faulty because it only displayed one hologram
Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
#4 Posted : 11 January 2019 18:54:44
Hi try replacing the circuit board from Issue 27 first.
shunte
#5 Posted : 18 January 2019 11:56:46
I have the same issue, it did work for both holograms before it was all connected, my camera also doesn't work so I need two replacement issues, the connection to the lightsaber ejection tube motor is also weak, I'll try soldering that first.
matt4tay
#6 Posted : 15 February 2019 15:37:07
Rank: Newbie
Also having this problem. Everything works perfectly except the images.
I just get a large white circle.
#7 Posted : 15 February 2019 20:40:12
You need a replacement issue 27 contact C/S for one.
