 Rank: Beginner Level 1 Groups: Registered
Hi,
I think this may have been on another post but i can't seem to find it again so starting a new one.
My R2 fails to start up altogether. I have checked the battery pack with a multimeter as suggested on other posts and the reading is good.
The only signs of life i get is if i push and hold the power button on the front, the lcd screen lights up and the blue lights in the legs turn on.
All the connections seem okay and i have tried it with mains connected and battery pack. I have checked the on off rocker switch and the symptoms above only happen when in the on position.
Is this a main board issue, is there anyway of checking where the power is getting lost?
Any advise would be appreciated.
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 11/01/2017 Posts: 89 Points: 259 Location: Lancashire, UK
What batteries are you using? Do you have a link to where you purchased them from?
Hi James I purchased the INR18650-30Q batteries recommended on other posts from 18650.uk
Blobster1975 wrote:Hi James I purchased the INR18650-30Q batteries recommended on other posts from 18650.uk So this one, button top? BATTERY LINK
Hi, Yes, they are the ones I purchased. I bought 3 pairs.
Are you getting 12.3 volts at the end of the battery box leed. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
It is an analogue multimeter but yes looks to be about that, just over 12V Thanks
Can you check all conections are good and that all labels have been allocated correctly please. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks, I'll have to dismantle R2 to get to some connections but will take a look and let you know
I’m getting the exact same symptoms as you. Just two LEDs on his legs and the one lcd panel when I keep hold of the buttons.
You had any joy dismantling yet? I’m going to try dismantle mine today. Multimeter readings look good.
Wonder if I should order a replacement MCU
m0nkey88 wrote:I’m getting the exact same symptoms as you. Just two LEDs on his legs and the one lcd panel when I keep hold of the buttons.
Wonder if I should order a replacement MCU Can you first provide a link to the batteries you have purchased?
I will be dismantling today and will let you know the progress
Tomick wrote:m0nkey88 wrote:I’m getting the exact same symptoms as you. Just two LEDs on his legs and the one lcd panel when I keep hold of the buttons.
Wonder if I should order a replacement MCU Can you first provide a link to the batteries you have purchased? I got these ones, they all test okay on a multimeter. And all charged to full using the supplied charger / tester. https://www.ecoluxshopdi...00mah-10a-button-battery
Blobster1975 wrote:I will be dismantling today and will let you know the progress Thanks Blobster1975, I’ll let you know how I get on too!
Hi, I have completed the dismantle and can confirm all cables are labelled correctly and the are no bent pins. Where do I go next. Thanks
Contact C/S for a replacement MCU. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
m0nkey88 wrote:Blobster1975 wrote:I will be dismantling today and will let you know the progress Thanks Blobster1975, I’ll let you know how I get on too! Could you start your own thread about your R2 problem please so we dont get conflicting sollutions to either of your problems. What is the battery reading you are getting at the end of the battery lead and across all batterys please. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote:Contact C/S for a replacement MCU. Thanks, how do I contact c/s please
Blobster1975 wrote:arpurchase wrote:Contact C/S for a replacement MCU. Thanks, how do I contact c/s please The number is on the inside front cover of the magazine, mon-fri 9-5
Thanks. I'll order and let you know if this resolves the issue.
