Beautiful Phil, top class work.... Regards Alan
Gandale wrote:Beautiful Phil, top class work.... Regards Alan Thank you very much Alan! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The PE looks excellent, nice detail. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:The PE looks excellent, nice detail. Mark Cheers Mark! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
It is a cool model with many details in love it
samson wrote:It is a cool model with many details in love it Thank you Jens! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Kev the Modeller wrote:Really getting to the nitty gritty now, with some nice details starting to be added. Will look fab when it's all painted.
Bet the fitting of all of those thousands of rivets to the hull seems like a very long time ago now eh Phil?!
Kev  Thank you Kev!  Yes, it's starting to take shape now. Ah, the riveting!  Those were the days! lol I still have a bit more riveting to do though when I build up the rudders, fore-planes and aft-planes, but that won't be for a few weeks yet. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good morning from 'The Dockyard'. This week continues with the addition of part-works supplied items to the conning tower. The first step was to prep the conning tower hatch by which all look-outs would gain access to the bridge. The only thing that I didn't like about the moulded plastic hatch was the spring. So i decided to cut this section out and replace it. The attached photo shows the moulded plastic spring removed. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then drilled through the hinges and fitted a small length of 1.5mm diameter brass tube. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
To fabricate the spring, i used a piece of solder wound around the brass tube and cut to suit. I then completed the hatch with the part-works supplied PE. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hatch in position, not glued at this stage as i will paint and weather it separately before fixing it permanently. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made up the search periscope mast housing as per the part-works instructions. Similar to the hatch, this will be painted and weathered separately before fixing in place. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made the attack periscope mast housing and will paint and weather as a separate item. The difference between the search and attack periscopes is that the search periscope is binocular, while the attack periscope is monocular and thus smaller in cross section and less visible, hence its name. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next item made as per the part-works instructions was the UZO; U-boat targeting sight. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows all of the masts and periscope housings temporarily fitted to give an idea of how they will look. As I've mentioned before, all of these items will be painted and weathered separately prior to fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Well that concludes this weeks update. Stay tuned for more work in progress next week. Thanks for looking in and your comments, have a great weekend and happy modelling. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looks amazing, detail being applied is superb.....  .. Another great update Phil, well done.... Regards Alan
Gandale wrote:Looks amazing, detail being applied is superb.....  .. Another great update Phil, well done.... Regards Alan Thank you very much Alan!  It's very satisfying when the small details are fitted, bringing the model to life. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (5)
