24 Pages «<1920212223>»
L'Hermione Build Options
samson
#401 Posted : 09 January 2019 19:01:32
looking great this small details Love
#402 Posted : 09 January 2019 22:09:25
Just catching up with your build Alan, some very nice detail. Looking excellent.Love
#403 Posted : 09 January 2019 22:52:57
#404 Posted : 09 January 2019 23:22:38
Very nice work on the stairs and bannisters Alan!Love Great attention to detail making this model a standout. Looking fantastic!
#405 Posted : 12 January 2019 23:52:23
Thanks to everyone who took the time to look in and especially to those that commented, very much appreciated all round....Cool Cool
In this build stage we move onto assembling the bow bell tower. Started with a 3x3mm wooden strip and cut two lengths of 40mm. Following the measurements given in the instructions I then cut a rebate in each length, 3mm wide and 1mm deep. Rebate is to accommodate the moulding surrounding the deck opening. Test fitted to ensure a good fit then painted the strips red..
Took the diecast bell housing top and cleaned off any burrs or casting lines, primed the piece and again painted red. Glued the top onto the two previously prepared wooded strips ensuring they were set 6mm apart and running parallel, left to dry fully before continuing.
From a remnant of 1x3mm strip then cut a piece 6mm in length, shaped the top as per the instructions. Applied a dark wood stain and left to dry. From the remnant also cut two pieces 2mm long and glued them onto the centre of the previously prepared piece, one on either side. Painted the two small pieces black and applied a 1mm black strip to either end of the completed assembly. Glued the assembly between the two uprights, 4mm from the bell tower top.
The diecast bell was filed to remove any burrs, primed and painted brass. From a length of 0.8mm brass rod, cut a 4mm length and glued to the centre of the bell to resemble the bell clapper. Once dried, then glued the bell in place. The completed assembly was then glue into position as shown in the instructions. This completed stage 51 so until next time, happy building all....Cool Cool
#406 Posted : 15 January 2019 00:07:10
In this build stage we create and fit the banisters to the stairways. From an 0.8mm brass rod I cut twelve 13mm lengths and filed the ends flat. These were then primed and painted black.
When dry, glued 3 of the prepared lengths onto each of the stairway sides following the measurements given in the instructions and ensuring all lengths were upright.
Took a length of 1x3mm wooden strip and cut 4 pieces each 25mm long. Sanded smooth, rounded off the ends and stained with a dark wood stain. When dry, glued the pieces onto the ends of the brass uprights again following the instructions on how they should be positioned. This brought an end to stage 51 so until next session, happy building all....Cool Cool
samson
#407 Posted : 15 January 2019 13:40:34
Love
it looks good your "bell tower"
#408 Posted : 15 January 2019 15:01:59
Beautiful work as always Alan, she's looking very impressive.
#409 Posted : 15 January 2019 16:26:07
very nice Alan. AYour doing an amazing job on her.
#410 Posted : 15 January 2019 19:12:32
#411 Posted : 15 January 2019 19:44:26
Some very fine detail there Alan. Nice build ThumpUp
#412 Posted : 15 January 2019 20:25:20
BigGrin Really tacking shape Alan lovely build Cool
Martyn
#413 Posted : 15 January 2019 22:19:25
Well done Alan
Those stair rails look like fiddly little blighters.Crying Crying
#414 Posted : 15 January 2019 23:41:31
She looks amazing Alan, great work.Love
#415 Posted : 16 January 2019 00:19:47
Thanks everyone for looking in and commenting, very much appreciated....Cool Cool
@Derek, must admit they did try may patience a little but proud to say I managed to keep the cursing to a minimum.....BigGrin BigGrin BigGrin .. Quite a lot of fiddly work on this build but I think it is all very much worth the effort....Cool Cool
#416 Posted : 16 January 2019 12:56:16
Looking fantastic Alan. Great build!Love
#417 Posted : 16 January 2019 13:31:02
Looking great!
#418 Posted : 16 January 2019 14:33:35
Hi Alan.
looking fantastic. love the capstan and bell tower. Cool BigGrin
daffy09
#419 Posted : 16 January 2019 15:01:54
Hi Alan
Just caught up with this one. Some great detail going into the build now, well done
Happy building
David
nightwisher
#420 Posted : 16 January 2019 15:27:37
Lovely neat work as always. There looks as much detail in this kit as some of the bigger partworks Cool
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
This page was generated in 0.183 seconds.
