1st magazine error? (Stage 16) Options
Deekity
#1 Posted : 09 January 2019 17:00:42
Everything so far has been smooth. I appear to have run into an error however.
On issue 16 step 13 has you line up parts.
In step 16 The metal pipework pieces labeled:
1)C and D SHOULD read E and F respectively if they are to fit as in the picture.
2)on step 17 the parts labeled E and F should read G and C
3)on step 17 the parts labeled G and H are in fact parts D and H
Can anyone else verify?
The original set-up picture should look instead like the attached image if you want the pieces to fit as in steps 16 and 17 in the magazine
#2 Posted : 09 January 2019 22:36:29
Hi,I can see how confusion of the parts can arise as none are marked A,B,C,D ect and its easy to mix them up if your not carefull.
Deekity
#3 Posted : 10 January 2019 16:16:56
I just can't see how? For instance the original line up is attached. See how parts C and D are completely straight and E and F have a bend. Now see stage 17 where it says E and F are in the top positions - that's not correct - those are clearly parts C and D - dead straight (also E and F are too short!! and you'll find C and D are too long for the positions the mag tells you to put them in). Also it says to use parts G and H together in stage 17 - it's clearly wrong as part G has a double bend (like part H) and the picture clearly shows a single bend (because it's actually part E)
#4 Posted : 11 January 2019 23:12:06
There is an editorial update which seems to have missed the magazine print run and the parts should be labeled as follows.
Stage 16, page 11, picture 13, from left to right the parts should be labeled-
A,B,F,E,C,D,H,G
Use the above letter sequence to identify the part correctly.
Stage 16, page 11, picture 16. A and B are correctly labeled, C should be part D, D should be part H.
Stage 16 , page 11, picture 17. E should be part F, F should be part E, G should be part C, H should be part G.
Earl McBroom
#5 Posted : 12 January 2019 21:46:01
Now I'm really confused several pipes broke on me
Earl McBroom
#6 Posted : 12 January 2019 22:20:21
Thanks guys unfortunately PAC 15 and 16 have broken parts due to me guessing the right placement of the pipes. Thank you all for correcting my problem. What a screw up I caused.
