R2 not starting up Options
Blobster1975
#1 Posted : 07 January 2019 13:27:58
Hi,
I think this may have been on another post but i can't seem to find it again so starting a new one.
My R2 fails to start up altogether. I have checked the battery pack with a multimeter as suggested on other posts and the reading is good.
The only signs of life i get is if i push and hold the power button on the front, the lcd screen lights up and the blue lights in the legs turn on.
All the connections seem okay and i have tried it with mains connected and battery pack. I have checked the on off rocker switch and the symptoms above only happen when in the on position.
Is this a main board issue, is there anyway of checking where the power is getting lost?
Any advise would be appreciated.
James H
#2 Posted : 07 January 2019 14:01:22
What batteries are you using?
Do you have a link to where you purchased them from?
Blobster1975
#3 Posted : 07 January 2019 15:10:37
Hi James
I purchased the INR18650-30Q batteries recommended on other posts from 18650.uk
James H
#4 Posted : 07 January 2019 18:51:37
Blobster1975 wrote:
Hi James
So this one, button top? BATTERY LINK
Blobster1975
#5 Posted : 07 January 2019 21:48:25
Hi,
Yes, they are the ones I purchased. I bought 3 pairs.
#6 Posted : 07 January 2019 23:04:19
Are you getting 12.3 volts at the end of the battery box leed.
Blobster1975
#7 Posted : 08 January 2019 00:06:05
It is an analogue multimeter but yes looks to be about that, just over 12V
Thanks
#8 Posted : 08 January 2019 06:45:42
Can you check all conections are good and that all labels have been allocated correctly please.
Blobster1975
#9 Posted : 08 January 2019 11:32:16
Thanks, I'll have to dismantle R2 to get to some connections but will take a look and let you know
m0nkey88
#10 Posted : 11 January 2019 09:46:04
I’m getting the exact same symptoms as you. Just two LEDs on his legs and the one lcd panel when I keep hold of the buttons.
You had any joy dismantling yet? I’m going to try dismantle mine today. Multimeter readings look good.
Wonder if I should order a replacement MCU
#11 Posted : 11 January 2019 10:11:43
Can you first provide a link to the batteries you have purchased?
Blobster1975
#12 Posted : 11 January 2019 10:51:26
I will be dismantling today and will let you know the progress
m0nkey88
#13 Posted : 11 January 2019 12:28:10
I got these ones, they all test okay on a multimeter. And all charged to full using the supplied charger / tester.
https://www.ecoluxshopdi...00mah-10a-button-battery
m0nkey88
#14 Posted : 11 January 2019 12:28:40
Thanks Blobster1975, I’ll let you know how I get on too!
Blobster1975
#15 Posted : 11 January 2019 13:09:52
Hi, I have completed the dismantle and can confirm all cables are labelled correctly and the are no bent pins.
Where do I go next.
Thanks
#16 Posted : 11 January 2019 19:09:26
Contact C/S for a replacement MCU.
#17 Posted : 11 January 2019 19:12:10
Could you start your own thread about your R2 problem please so we dont get conflicting sollutions to either of your problems. What is the battery reading you are getting at the end of the battery lead and across all batterys please.
Blobster1975
#18 Posted : 11 January 2019 22:23:17
Thanks, how do I contact c/s please
#19 Posted : 11 January 2019 22:34:54
The number is on the inside front cover of the magazine, mon-fri 9-5
Blobster1975
#20 Posted : 11 January 2019 22:43:07
Thanks. I'll order and let you know if this resolves the issue.
This page was generated in 0.346 seconds.
