Completely dead R2 Options
Mr_heisenburg
#1 Posted : 05 January 2019 15:05:32
So I finished my R2 before Christmas but had to wait till now to get the batteries. I bought the pink Samsung button top unprotected batteries. I’ve charged them as per the instructions , fitted them in , plugged the mains in for a few seconds and switched off then switched him on for the first time........nothing.... not a light...a movement...a sound.........I’ve checked the connections in the battery box , they look good , checked all connectors and pins...all good but still completely dead......Anyone else experienced this..... any suggestions would be appreciated.....
#2 Posted : 05 January 2019 16:50:24
Could you borrow a voltage meter and test the contacts at the end of the lead on the battery box.
Mr_heisenburg
#3 Posted : 05 January 2019 17:02:31
I’m going to go and grab a voltmeter in a while....... I will post my findings......
Mr_heisenburg
#4 Posted : 05 January 2019 19:27:43
Ok.....I’ve checked the batteries....each one is reading between 4.13 and 4.15 so I’m guessing they are sound. However when I measure the voltage at the end of the red and black power connector from the battery box I’m getting zero volts......all the batteries are fitted correctly and looks like all the button tops are touching......
Steve1701
#5 Posted : 05 January 2019 19:31:28
have you pressed the bottom button on the front of the unit.
Mr_heisenburg
#6 Posted : 05 January 2019 20:07:12
Yeah, I have followed the instructions to the letter. ...
tschwand
#7 Posted : 05 January 2019 20:26:56
Read elsewhere on the forums that some batteries are not making good contact in the box at the positive terminal. Some because of an issue with the box, some because the button tops are not full button tops, but just stubby tops.
Mr_heisenburg
#8 Posted : 05 January 2019 22:24:05
I have bought the Samsung 30q button top batteries which a lot of people have used with success with R2. That’s why I bought them also.... they are definitely in the battery box nice and tight and making contact with the positive terminals.........
CT71
#9 Posted : 05 January 2019 22:28:21
I made that mistake the first time when thinking mine didn't work, just pressed the main power switch on his "bottom" BigGrin
#10 Posted : 05 January 2019 22:32:33
Have you checked the power output from the batterys in situ in the battery box if there all making contact with the box you should get around 12.3 volts total from the batterys.
Mr_heisenburg
#11 Posted : 05 January 2019 22:38:50
Yes......I’ve put the meter across the black and red power wire connector and I’m getting zero volts......
#12 Posted : 05 January 2019 22:47:11
You missunderstand me I meant to test from the first battery across to the last battery across the battery box.
Mr_heisenburg
#13 Posted : 05 January 2019 22:51:18
When I put the volt meter inside the battery box and measure on the terminals where the batteries touch I’m getting readings of 4.14v on the first 2 batteries, 4.14v on the middle 2 batteries and 4.14v on the final 2 batteries. Therefore there’s power inside the battery box directly on the terminals but there’s zero volts at the end of the wire which connects into R2’s mcu.
Mr_heisenburg
#14 Posted : 05 January 2019 22:53:02
Sorry....yes...from the first battery to the last battery I’m getting 12.44v
#15 Posted : 05 January 2019 22:56:29
I think you may have a dodgy battery box please contacy C/S for a replacement. You can find the number for C/S on inside of the first page of the instruction book.
Mr_heisenburg
#16 Posted : 06 January 2019 00:45:06
Ok thanks.....I’ll get in touch with cs about a replacement.....
