Arm Motor Options
Tills
#1 Posted : 05 January 2019 11:09:17
Rank: Beginner Level 3
Morning, does anyone have an easy way to change the arm motor on a complete R2-D2. The cable has come away from the motor...... may just do without the arms movingConfused Thanks
#2 Posted : 05 January 2019 11:18:55
You may want to order a replacement from c/s. Just means you will need to remove the rear and front panel to replace.
Tills
#3 Posted : 05 January 2019 14:25:27
Thanks Mark. Now the speaker has decided to stop working. Don’t understand as everything has been fine. In fact it seemed to be working better than most. Not sure what to do now. No sound in talk mode or whilst playing the holograms. All connections are good, faulty speaker?
Hyperdrive Kid
#4 Posted : 26 January 2019 23:04:58
I just read on here somewhere that there is a mute function for the speaker...maybe check the settings.
Tills
#5 Posted : 27 January 2019 12:54:36
BigGrin
This page was generated in 0.116 seconds.
