24 Pages «<1819202122>»
L'Hermione Build Options
daffy09
#381 Posted : 05 August 2018 00:08:53
Nice work Alan
Happy building
David
#382 Posted : 05 August 2018 08:07:28
#383 Posted : 06 August 2018 14:34:11
Thanks guys, appreciated...Cool Cool
#384 Posted : 07 August 2018 10:51:33
Nice update!
#385 Posted : 07 August 2018 12:45:28
Great work Alan.Love
#386 Posted : 18 December 2018 11:14:18
Found some time so thought I'd try and move this one forward a little more. In this stage we move on to creating the foremast pulley. Started by taking a 4x6mm wooden strip ensuring the end was cut square. Marked two lines all the way around the strip, 2 and 4mm down from the to, then used a small round file to shape a groove all the round the strip between the marked lines. Next step was to shape the top of the pulley using a sanding block.
Followed the measurements set out in the instructions and marked out the position of the rigging holes ready for drilling. Drilled the six 1mm holes, the best way I find to do this is to mark out the hole positions on both sides of the strip then drill half way through from each side. Once done gave the piece a light sanding over to smooth then cut the pulley off the strip, 14mm from the top.
Painted the pulley red and glued into position as per the measurements given within the instructions. This completed stage 47, next is the assembly of the first deck winch (capstan). Until then, happy modelling all....Cool Cool
#387 Posted : 18 December 2018 22:46:19
In this stage we assemble the First Deck Winch (Capstan). Took the winch body and attached the 6 pre-formed supports. The supports needed to be lined up directly under the holes in the body where the handles fit. Once dry I then painted the winch with our favourite red....Cool Cool.. When the red had dried I then painted the 3 round edges black.
Took a 0.8mm brass rod, cut 6 lengths 17mm long and filed the edges to remove any burrs, these will be for the winch handles. Handles were then glued in place ensuring they were evenly spaced and all sitting at the same level. Once dried, the handles were then given a coat of primer before painting brown.
Finally, glued the winch into position as shown in the instructions. This brings to an end stage 48 so until next time, happy modelling all....
daffy09
#388 Posted : 19 December 2018 17:10:10
Hi Alan,
great job on the capstan. Good to see you back to work on her again.
Happy building and seasons greetings
David
#389 Posted : 19 December 2018 23:55:07
Thanks David, appreciated....Cool Cool
#390 Posted : 20 December 2018 10:34:39
Hi Alan, great work in making the foremast pulley. Really nice bit of work you've done there. The ship is coming along a treat.
#391 Posted : 20 December 2018 21:37:46
Thanks Phil, appreciated.... One thing for certain, she's going to be a bright and colourful build....Cool Cool
#392 Posted : 20 December 2018 22:09:54
Beautiful work as always, looking superb.
#393 Posted : 21 December 2018 08:31:37
Very neat work - great update!
#394 Posted : 21 December 2018 12:23:49
Graeme, Walter, thanks for looking in and your comments, appreciated....Cool Cool
#395 Posted : 30 December 2018 13:24:14
In this build stage we are required to assemble 4 stairways. Looked at the stairway sides which were pre-cut and here is where I encountered a problem. There just wasn't any way I could get two sides to match, meaning I would have ended up with some very wonky stairways. Only solution was to fabricate my own from 2x4mm wooden strips. Took a while as they kept breaking but eventually got there. Stairway sides were then painted red and left to dry.
Cut 25 pieces of 1x5mm wooden strip for the treads, 5 pieces for each stairway. Glued the top and bottom tread onto the stairway sides ensuring the assembly was square, then left to dry. Once dried then inserted the remaining 3 treads, did this for the 4 stairways.
Test fitted and adjusted the stairways for a good fit. Finally painted a 1mm dark brown strip along the bottom of each stairway side. When happy glued the 4 stairways in place. This completed build stage 49 so until next time, happy modelling all....Cool Cool
daffy09
#396 Posted : 30 December 2018 14:14:09
Nice work on the stairways Alan. Glad you found a way to 'cure' the problem with the kit parts, they look good in situ.
Happy New Year and happy building
David
#397 Posted : 30 December 2018 22:11:34
Thanks David, appreciated. The only way to resolve the issue was to construct my own ladder sides from 2x4mm wooden strips, either that or wait for replacements to arrive....Huh Huh
samson
#398 Posted : 03 January 2019 22:59:41
hello Allan it looks exciting your "new project ship" yes that is the long time since i have looked in and then you were still on the Sovereign of the Seas. It seems you have come a long way since then. And what you build is fabulous
Jens.
#399 Posted : 04 January 2019 00:24:28
Jens.
Thanks for the kind comments Jens, always appreciated...Cool Cool .. Modelling never stops, done a few things since SOTS and have lots more yet to do. Stash gets bigger, whether it will all get done is another matter....BigGrin BigGrin .. Will keep at it though BigGrin … Thanks again..
#400 Posted : 09 January 2019 11:09:30
Here we move onto creating the banisters that will sit either side of the bell tower. Started with a 2x2mm strip, painted it red and cut two 13mm, two 12.5mm and two 12mm lengths. Shaped the tops of the strips and touched up with red paint.
Separated the two PE parts from the PE fret, cleaned up the edges and primed. Both sides then painted yellow and left to dry. Removed the pre-cut frame tops from the fret, sanded the edges smooth and painted red, then assembled the two banisters as per the instructions noting there is a slight slope to these. When fitted the slope will run from the centre of the deck out towards the hull sides. When the assemblies had dried fully they were then glued in place.
From an 0.8mm brass rod, cut 8 lengths of 6mm, filed the ends flat then primed and painted black. Glued the lengths in place on top of the banisters noting the measurements given in the instructions.
Took a length of 1x3mm strip, cut two pieces 24mm long, sanded smooth and rounded off the ends. Stained these with a dark woodstain then carefully glued these to the tops of the brass rods fitted in the previous step, following the slope. This brought stage 50 to an end and in the next stage we work on the bell tower. Until then, happy modelling all....
This page was generated in 0.215 seconds.
