Joined: 02/01/2019 Posts: 17 Points: 51 Location: London
Hi i just completed R2D2 and he wont work. Do i have the right batteries? https://www.ebay.co.uk/i...sid=p2057872.m2749.l2649
There are several batteries available in the link you’ve provided, but it’s looks like the batteries you’ve purchased are protected ones, they should be Unprotected. The spec you need: Type: 18650 lithium-ion batteries 3.7v (or 3.6v) 'nominal' Button-top At least 3 Amps capacity discharge At least 2000mAh capacity - (recommend 2600-2800mAh) "Unprotected" battery type Some members have purchased this battery which meets the spec: https://18650.uk/product/samsung-30q-button-top/
Regards Mark Regards Markwarren (Mark) Admin
