Steven123 Options
Steven123
#1 Posted : 30 December 2018 12:44:53
Working on carpet?
My r2 stops starts so much it rocks it’s self over, I take it there not ment for carpet?
DC-Zol.
#2 Posted : 30 December 2018 15:44:40
Rank: Amateur level 2
Steven123 wrote:
Working on carpet?
Easy fix -
* Remove the 4 screws at the base of the middle foot.
* Then remove the caster wheel (nut, spring washer, washer).
* Next add a couple of extra washers or the nut you should have spare onto the caster wheel before putting it back on the base of the middle foot (you may need to hold the base of the caster wheel tightly to redo up, but it's not impossible).
* Reattach base of foot and the added clearance should give a better ride height for R2 whilst still looking okay & not jacked up
Steven123
#3 Posted : 30 December 2018 23:09:45
Nice one cheers will have ago
This page was generated in 0.165 seconds.
