4 Pages <1234>
Graham's Easy Rider Build Options
bugsec
#41 Posted : 28 December 2018 00:25:29
Build Stage 12 - The upper exhaust pipe.
Parts required:
A, B, C and D from Parts 11
Also required:
The upper silencer from Stage 11.
Brackets A and C are fitted to the exhaust pipe. The exhaust pipe is attached to the silencer and held with bracket D.
bugsec attached the following image(s):
bugsec
#42 Posted : 28 December 2018 00:26:41
Build Stage 13 - The lower silencer.
Parts required:
A, B, C, D and E from Parts 12
Also required:
The two parts of the silencer are fitted together and the brackets added to hold in place.
bugsec
#43 Posted : 28 December 2018 00:27:41
Build Stage 14 - The lower exhaust pipe.
Parts required:
A, B and C from Parts 13; F from Parts 14.
Also required:
The lower silencer from Stage 13.
The two exhaust pipe sections are fitted to the silencer and held using the brackets.
bugsec
#44 Posted : 28 December 2018 00:28:46
Build Stage 15 - The horn.
Parts required:
A, B, C, D and E from Parts 14.
Also required:
The cable from the circuit board if fed through the horn case then the circuit board is fitted into the recess in the case. The horn cover is fitted onto the front of the horn case then the mounting plate is fitted to the rear of the horn case.
#45 Posted : 28 December 2018 08:49:28
Nice update and looking good Cool
#46 Posted : 28 December 2018 09:23:31
Coming on very nicely. Great update. Cool
#47 Posted : 28 December 2018 10:55:57
Very nice work indeed, making beautiful progress....Drool Drool
#48 Posted : 28 December 2018 11:04:31
BigGrin All looking good from here and nicely doneCool
bugsec
#49 Posted : 28 December 2018 14:18:02
Thanks for looking in and the kind comments guys. My New Year Resolution will be to keep up to date with builds and build diaries LOL
Graham
#50 Posted : 05 January 2019 23:13:46
Your build is coming along very nicely, good work.
#51 Posted : 06 January 2019 00:58:41
Nicely done Graeme BigGrin will be following your build.
bugsec
#52 Posted : 16 March 2019 13:34:07
Thanks all for the kind comments.
Pack 04 contains Stages 16 - 21
Parts supplied:
Parts 16:
A - Number Plate
B - Number plate mount and rear light
C - Screws
Parts 17:
A - Left body frame
Parts 18:
A - Clutch linkage
B - Clutch linkage plate
C - U-shaped clamp
D - Screws and fittings
E - Spring
F - Linkage road
Parts 19:
A - Gearshift pedal plate
B - Linkage arm
C - Linkage
D - Gearshift pedal
E - Pedal rubber
F - Fittings
Parts 20:
A - Right body frame
B - Screws
Parts 21:
A - Footbrake plate
B - Footbrake pedal
C - Brake pivot
D - Linkage
E - Fittings
bugsec
#53 Posted : 16 March 2019 13:36:14
Build Stage 16 - The number plate
Parts required:
A, B and C from Parts 16
Also required:
The sissy bar from Parts 15.
The number plate mount is fixed to the sissy bar using the provided screws. The number plate is then fitted to the number plate mount using the pins on the number plate.
bugsec
#54 Posted : 16 March 2019 13:37:14
Build Stage 17 - The body frame
Parts required:
A from Parts 17 and A and B from Parts 20
Also required:
The two frames halves are aligned then fixed using the screws provided.
bugsec
#55 Posted : 16 March 2019 13:40:22
Build Stage 18 - The clutch linkage
Parts required:
A, B, D (some parts), E and F from Parts 18
Also required:
The bolt with the eye is fixed to the clutch linkage using the nuts. The clutch linkage and the clutch linkage plate are fixed togetjer using the washer screw. The linkage rod is secured to the linkage plate with nut and bolt. Finally the spring is connected between the eyebolt and the post on the linkage plate.
The remaining parts are stored for later use.
bugsec
#56 Posted : 16 March 2019 13:41:32
Build Stage 19 - The rear brake
Parts required:
A, B, C, D, E and F from Parts 19
Also required:
The pedal rubber is fitted to the gearshift pedal. The gearshift pedal and linkage arm are then secured to the gearshift pedal plate using a washer screw. The post on the end of the linkage is fitted into the end of the linkage arm and secured with a nut and bolt.
bugsec
#57 Posted : 16 March 2019 13:42:34
Build Stage 20 - The footbrake
Parts required:
A, B, D and E (some parts) from Parts 21
Also required:
The bracket is attached to the linkage using the nut and bolt. The linkage is attached to the footbrake pedal using another nut and bolt. The footbrake pedal is attached to the footbrake plate using the bolt supplied.
bugsec
#58 Posted : 16 March 2019 13:43:45
Build Stage 21 - The brake pivot
Parts required:
C and E (some parts) from Parts 21
Also required:
The pin is inserted into the brake pivot.
All unused parts from the pack are stored for later use.
bugsec
#59 Posted : 16 March 2019 18:16:22
Pack 05 contains Stages 22 - 27
Parts supplied:
Parts 22:
A - Brake disc
B - Sprocket
Parts 23:
A - Drive chain
Parts 24:
A - Crankcase
B - Tappet guide
C - Plug
D - Washer screws
Parts 25:
A - Transmission case
B - Screws
Parts 26:
A - Screws
B - Oil filter top
C - Oil filter
Parts 27:
A - Screws
B - Transmission cover
C - Distributor base
D - Gasket
E - Distributor
bugsec
#60 Posted : 16 March 2019 18:18:12
Build Stage 22 - The transmission
Parts required:
B, C and D from Parts 24, A from Parts 25.
Also required:
The plug is inserted into the tappet guide then the tappet guide is attached to the transmission case using a screw.
4 Pages <1234>
This page was generated in 0.373 seconds.
