Akagi Builds in plastic 1:350 reference.. Options
#1 Posted : 18 July 2011 11:45:14
Heres a few links to some Akagi builds..Awesome springs too mind..
And a link for a build in pics on youtube...
http://www.modelshipgall...-350-pvb/pvb-index.html
http://www.shipmodels.in...ic.php?f=59&t=54087
http://www.youtube.com/watch?v=pwF5GNldcdc
#2 Posted : 18 July 2011 12:01:16
Yes I will give you that!!!! awesomeBigGrin LOL
allanc62
#3 Posted : 19 July 2011 17:57:35
Found this site
http://www.hasegawa-model.co.jp/akagi/Z25E.html
wonder if the agostini model will be this detailed
#4 Posted : 19 July 2011 19:21:53
I asked MR T the same as those builds above are all of that kit but he says to look at the advert pics thats all he can give on the matter,,
I hope myself that it is.. The Hasagawa kit is £300 plus you need to buy each of the P/E kits to go with it then the aircraft are seperate too. Works out around £500 for the kit.. And its smaller 1/350 where as ours is 1/250..
Chris...
budgie
#5 Posted : 19 July 2011 19:28:28
Blushing Blushing can anyone tell me what the water is being pumped over board
Surely too big for bilge pumpsConfused
or is it a ballast pump to raise/lower ship due to weight of aircraftConfused
Ta
#6 Posted : 19 July 2011 20:30:27
Hope this helps...
Akagi was given two funnels on the starboard side. The larger, forward funnel was downturned 120° with its mouth facing the sea and the smaller one exhausted vertically a little past the edge of the flight deck. The forward funnel was fitted with a water-cooling system to reduce the turbulence caused by hot exhaust gases and a cover that could be raised to allow the exhaust gasses to escape if the ship developed a severe list and the mouth of the funnel touched the sea.
Chris..
budgie
#7 Posted : 19 July 2011 20:45:04
Cheers Chris
