Power Up Test Fails? Try disconnecting the charger! Options
DC-Zol.
#1 Posted : 23 December 2018 13:14:49
Rank: Amateur level 2
Failed Power Up Tests?
**VERY IMPORTANT**
R2 will NOT power up fully if you have the mains adapter/charger plugged in, it won’t complete the power up as R2 thinks it’s just charging the batteries!
If your R2 doesn’t jerk forward or whistle at the end of head rotation this could be the reason why, so disconnect & retry
It’s a simple thing, but easily overlooked
#2 Posted : 23 December 2018 13:29:00
If you follow the start up instructions to the letter it tells you to that.
DC-Zol.
#3 Posted : 23 December 2018 13:36:23
I've seen a lot of videos where people are saying they are having issues starting up, but the charger is still plugged in :D - it's good to remind them. ;)
This page was generated in 0.083 seconds.
