 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hello again sorry for all of the questions but I have two more 1) in the video I forgot the issue but what is the silver sensor devise going into R2's upper part of the legs in the back side in issue 30 and seen installed in issue 55 2) I notice issue 89 is repated as issue 90 what is up with that, it a waist of an issue Ronald
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,869 Points: 20,924 Location: Northamptonshire, England
The sensor is the shoulder sensor and issue 89 and 90 are not the same they are the two halves of the complete foot. Take a look at the official build here which details all the parts as it is constructed. https://forum.model-space.co.uk/....aspx?g=topics&f=446Hope that helps Regards Mark Regards Markwarren (Mark) Admin
OOH I see now thanks Mark just two more questions plus I will follow your build also any way first question what does the shoulder sensor do second question why does the transit PCB cover need to be removed or was it designed to be removed and only enclosed for transport or was it the cover got in the way of being installed in chassie thank tyou Ronald
ronald305 wrote:OOH I see now thanks Mark just two more questions plus I will follow your build also any way first question what does the shoulder sensor do second question why does the transit PCB cover need to be removed or was it designed to be removed and only enclosed for transport or was it the cover got in the way of being installed in chassie thank tyou Ronald
The shoulder sensor will sense objects when in patrol mode. The cover is merely a protective cover. Mark Regards Markwarren (Mark) Admin
