Blue light in foot Options
luigione
#1 Posted : 22 December 2018 15:16:21
Just noticed a blue light in one foot, should there be one in both? Is it a status light? R2D2 seems to be working fine,if only a bit deaf, doesn't seem to like voice commands and I haven't noticed any malfunctions apart from nearly diving down a step, apparently dark surfaces aren't perfect for his sensors.
#2 Posted : 22 December 2018 17:28:01
The blue lights come frome an led attached the circiut board on the end of the foot motors . Your light may have just failed at some point, the motor should work fine without the LED working.
semaj
#3 Posted : 22 December 2018 17:53:44
Can i hijack this slightly (sorry) why on earth was a bright blue led put on them in the 1st place?
Building:
Complete:
#4 Posted : 22 December 2018 19:05:43
It’s not one we’re likely to get an answer on.
luigione
#5 Posted : 22 December 2018 20:14:17
Everything else is fine, so I guess it's something we can do without. I'm building a second one, just waiting on last 3 issues, so I'll be able to compare the behavior of both.
Mustang
#6 Posted : 23 December 2018 12:38:20
A simple fix is to add some black insulating tape to the inside of the foot.
It only take a couple of minutes, undo the four screws and add three strips of tape to the bottom half of the foot piece you removed and a piece along the back and hay presto the blue light doesn't show.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
