2 Pages <12
R2D2 doing nothing? Options
pandora648
#21 Posted : 21 December 2018 20:54:00
Quercus wrote:
pandora648 wrote:
Quercus wrote:
Still no luck but I've noticed that as well as the rear display, there is also a blue light coming on in his left and right foot when I press the bottom button. It only stays on whilst the button is pressed in . . . anyone got any other thoughts to help me out?
Have you got plastic branding wraps on your batteries? I had the same issue as you and I had wraps on my batteries that were causing no contact due to the plastic brackets in the battery box and the wraps, making the battery avoid contact by an incredibly small margin. I had to unwrap mine and now it works fine. Obviously I don’t encourage you to do this if you’re not comfortable as these types of batteries can be very danagerous if tampered with. But it is something to consider.
Hi. Thanks for that. You had the same issue exactly? I have bright pink wraps on my batteries but as far as I can tell both ends of the batteries are touching the contacts in the battery box? Were yours the Samsung branded ones?
Just to be clear, mine were rebranded Samsungs with additional wraps over the standard pink Samsung ones, the pink wraps are part of the original cell and shouldn’t be removed or you are playing with fire. I work in wireless radiocommunications and we use lithium batteries in a daily basis so I am comfortable with doing what I did. Don’t attempt to do so, I was using it as an example as even the slightest gap can be the fault you’ve expoerenced.
Quercus
#22 Posted : 21 December 2018 21:04:49
Ok so short of removing the plastic (which I'm being told is a terrible idea) do you have any tips on how i can improve the positive connection? You said you had the same issue as me and it solved it?
#23 Posted : 21 December 2018 21:39:25
The best way to check if the batterys are making full contact in the box is to try and borrow a multimeter and test the plug contacts, if it tests at just over 12 volts all the batterys are seated correctly and we can start to try and solve any other issues after that.
Quercus
#24 Posted : 21 December 2018 21:43:15
Ok thank you. I'll try that and get back to you if that's okay?
2 Pages <12
This page was generated in 0.133 seconds.
