Another Red light Fault Options
cozzie80
#1 Posted : 20 December 2018 23:31:20
Rank: Newbie
another Red light Fault
as with the topics posted by Jonnyc1988 and NeoFuture
I am having the same issue/fault a few people are having. All finished, batteries charged, initialized. Started up, jumps forward, dome doesn't spin. Red light. I have fully stripped all the wiring and ensured it is labled and seated correctly I have the recommended batteries -
[i][i]•Brand: Samsung SDI
•Model: 30Q
•Size: 18650
•Chemistry: INR
•Nominal Capacity: 3000mAh
•Nominal Voltage: 3.6V
•Discharge: 15A Max Continuous
•Positive: Button Top
•Protected: No
•Rechargeable: Yes
•Dimensions: 18.23mm x 64.78mm
•Weight: 46.1g
they are fully charged.
any help would be greatly appreciated
#2 Posted : 21 December 2018 06:52:39
Can you check your battery's are making full contact with the positive contacts of the battery box.
cozzie80
#3 Posted : 21 December 2018 07:17:08
Rank: Newbie
I can confirm that they are making contact correctly on all 6 batteries,
after a long night stripping down again and re confiming that everything is labled and plugged in correctly it now does the same as neofutures does in his video - https://www.youtube.com/...J4&feature=youtu.be
NeoFuture
#4 Posted : 21 December 2018 12:53:41
Rank: Beginner Level 3
Ive ordered a replacement MCU, im waiting for it to arrive, hopefully thats where the issue is. it would be nice to get some replication and feedback from the mods as a few people have the exact same issue.
cozzie80
#5 Posted : 23 December 2018 17:21:53
Rank: Newbie
Does any one have any more information on this?
PeterP
#6 Posted : 23 December 2018 17:35:42
I have this problem still and posted it on the 17/12 i have check everything ...four times!, i was also told that using protected batteries would cause a problem with the MCU but other people have this problem and they used unprotected batteries, i replaced them with unprotected ones now but he problem persists so the problem may be with a faulty MCU i have order a new one and have now stripped my R2 in preparation, the current MCU looks fine no bent pins or anything like that, so i await the new MCU and hope my problem end there
cozzie80
#7 Posted : 13 January 2019 16:05:45
Rank: Newbie
Success
After receiving a replacement MCU and installing it I have got r2 to work.
self test doesn't quite do as it says it should but once it gets past it I have full functionality.
I surmise it must have been a bad batch of MCU issues.
This page was generated in 0.280 seconds.
