Bees wax removal Options
goddo
#1 Posted : 18 December 2018 13:30:46
I wonder if anyone can help with a small problem regarding bees wax?
I have been diligently using the wax to help with building of the rigging but I now notice that, despite what I thought had been a thorough job of rubbing the wax into the thread, there are a lot of whitish marks remaining. Any ideas on how I can remove this, or have I been applying too much wax? All help would be appreciated.
#2 Posted : 18 December 2018 14:02:53
With beeswax you need to run the rigging thread through your fingers many times to warm it so to melts into the thread which stops the white looking thread. I normally only pull the thread through the block three times then roll the thread between fingers.
I have used in the past a quick pass through a candle flame which de furs the thread aswell but there is an element of danger with it being a flame. It would be your own responsibility if you chose to do it this way.
#3 Posted : 18 December 2018 14:22:12
A hot air gun or hairdryer should also do the trick
goddo
#4 Posted : 18 December 2018 15:21:00
Thank you Gents.
I will try the hot hair dryer first I think.
If you see flames coming from my house, I also tried the candle or cigarette lighter option!!
This page was generated in 0.117 seconds.
