R2D2 turns only one way Options
Bazzahibbs
#1 Posted : 17 December 2018 17:48:58
Rank: Newbie
Good Evening Fellow Builders
I recently finished building my R2D2, set up all well but only problem is his left leg wheel does not move, don't work for the app or front button pressed commands.
Any help would be grateful
Cheers
figuerres
#2 Posted : 17 December 2018 18:00:10
Cheers
check the cables that go from the leg to the control unit. one or more must not be fully plugged in or missing a pin.
use the test board to check the leg by its self. then check the plugs going into the controller.
Bazzahibbs
#3 Posted : 17 December 2018 18:37:22
Rank: Newbie
Thank you, I will check that
