R2 25 month subscription Options
ronald305
#1 Posted : 17 December 2018 15:46:45
Hello there everyone
can someone explain R2D2 subscription plans which one is closest to a full kit
thank you
Ronald
#2 Posted : 17 December 2018 16:10:59
Hi Ronald
You have both a 12 and 24 month subscription, depending how you want to stretch your finances, both with standard and premium subscription.
The premium comes with 3 collectible figures. Darth Vader, C-3P0 and R2-D2
If you order before 20th December you get 25 percent off.
#3 Posted : 17 December 2018 16:21:28
You will get the kit quicker with the 12 month plan.
#4 Posted : 17 December 2018 16:23:06
Currently the fastest way to a full R2-D2 kit is a 12 month Subscription
Also, R2-D2 is currently in the Christmas Sale with 25% off until the 20th Dec 19.
$97.49per month instead of $129.99 per month for the Standard subscription (inc R2 Binder & R2-D2 USB gifts)
Or as a Premium Subscription for $104.99 per month instead of $139.99 per month. (Premium subscribers also receive the Darth, R2-D2 and C-3PO hand-painted cold cast resin porcelain figurines in addition to the Standard gifts (R2 Binder & R2-D2 USB stick).
All that said, its likely that R2-D2 will at some point in future, be available as an "all in one go" full kit, but you won't then get 25% off as the sale will have ended.
ronald305
#5 Posted : 17 December 2018 16:27:18
ok thanks guys
wasn't sure which way to go
Ronald
#6 Posted : 17 December 2018 16:49:25
ronald305 wrote:
ok thanks guys
Ronald
Its also quite a lot of parts to assemble so the 12 month option will give you plenty to do each month.
This page was generated in 0.170 seconds.
