15 Pages «<7891011>»
Fozys Build Options
Foz
#161 Posted : 14 July 2011 16:03:36
Hi Mr T
I am going to be painting the hull so thats why i added the rudder now.
Hi Jonny
Well mate i know what you mean about the glue fumes, ive been sitting in that room most of the morning and had to have the window right open, only troubly is its a we bit windy up here on the 10th floor.
Well a short break now then back to the deck beams, im almost halfway done with them so ith any luck ill be able to start the planking tomorrow.
Foz
Foz
#162 Posted : 14 July 2011 20:16:57
So then
In between hospital visits i have been busy today and have mede a little progress.
I now have the suport beams for the quarter deck in place.
Will trim the frames and start the plankin tomorrow as i need a break now and some food.
But thanks to Darren for the help with the mast holes as the instructions in the mag not that good.
See you tomorrow with my updates.
Foz
Tiswas
#163 Posted : 14 July 2011 21:57:33
Looking good Foz. Going back to the cannon balls, I coated them with a layer of clear varnish after the initial fixing, just to make sure they are held tight. happy b uilding.
TIS
Foz
#164 Posted : 14 July 2011 22:16:56
Hi Tis
I put a coat of varnish on to start with. but that dod not hold all the cannon ball in pce so added nother good thick coat after and it dod the trick>
Foz
Foz
#165 Posted : 15 July 2011 15:18:43
Well started the quarter deck today and found out that the ugly twist i had earlier is still showing its ugly head with the planking in place.
Well time for a short break then back to it.
happy building
Foz
jonny7england
#166 Posted : 15 July 2011 15:50:01
She's looking absolutely brilliant Foz...I've just finished putting the cannon together...So, I'm a bit high on super glue fumes at the moment...row-row.row the boat..gently down the stream...LOL LOL
Foz
#167 Posted : 15 July 2011 16:05:55
Johnny, dont get to hight and think you can take the vic for a sail LOL
On another note i never knew id be doing such fiddly little parts when i started this build, but im getting there.
Foz
#168 Posted : 16 July 2011 18:48:21
Well then
Have finaly finished the quarter deck planking so here is what she is like before i stained it.
And after.
Allthough i used the same satin as on the upper gun deck it seems to look a bit darker. But i can live with it.
Foz
jonny7england
#169 Posted : 16 July 2011 18:57:58
She's coming along leaps and bounds Foz...Brill work mate...ThumpUp
#170 Posted : 16 July 2011 19:02:47
Foz,LOL BigGrin ThumpUp the whole build is a credit to you, love the planking-----you should be very proud of yourself
grab
#171 Posted : 16 July 2011 21:56:40
Rank: Amateur level 2
Coming along nicely matey
amipal
#172 Posted : 17 July 2011 19:23:21
Excellent work! ThumpUp
Quick question: how do you apply the stain so neatly? Whenever I try (using the Admiralty Walnut wood stain), it always comes out a bit hit and miss.
Foz
#173 Posted : 17 July 2011 19:52:51
Amipl
I just use cheap wood stain from Wicos, trhere own brand and use a normal paint brush, but just use it along the same way as the planks laid.
Hope this helps
Foz
#174 Posted : 17 July 2011 20:41:29
Looks great mate, Keep it up..BigGrin
Lonestar Spirit
#175 Posted : 18 July 2011 12:09:21
Looking brill mate! keep it up!!!!
Ship Builds on the go
farrabass
#176 Posted : 18 July 2011 15:33:54
Good to see your back on line after the problems with the gallery. I hope things run a little smoother for you from now on.
Foz
#177 Posted : 18 July 2011 20:17:21
Thanks for all the kind words lads, its much appreciated. Im now missing the build as im stuck on camp untill Saturday evening so will not get to much done then, but hopefully and update will be on here then.
Once again. Thanks lads.
Foz BigGrin
#178 Posted : 18 July 2011 20:22:23
Hi fozy where are you,Confused Confused I have just sent apost to you about cabin Partitions, to somewhere, but this is a different thread, Oh well what do I knowConfused LOL Blink Huh
Foz
#179 Posted : 18 July 2011 20:25:20
LOL MWG
This thread is my build diary.
Foz
#180 Posted : 18 July 2011 20:27:53
Laugh Thanks Fozy, ah well to much wine!!!!!!!!!!!!!!!BigGrin
Guest (10)
