R2d2 head motor trouble Options
Fergin
#1 Posted : 15 December 2018 22:48:00
Finished model
Powers on, red light on, but head does not move
Took apart and double checked all connections
Tried again but head does. It turn, just red light, manually moved head left and right and other sensors come to life, looks like motor u/s, contacted deagostini about motor, is there anything else to try
Fergin
#2 Posted : 15 December 2018 22:49:54
To start with could you provide the full spec of your batterys please. Also are all your labels correctly located on the cables.
Fergin
#3 Posted : 15 December 2018 23:21:22
Cheers
Battery is 18650 Battery 3.7V 3600mAh BRC Rechargeable Li-ion Lithium Cells
Checked all connections about 5 times now, all ok
Cheers
Fergin
#4 Posted : 15 December 2018 23:23:53
Could you provide me with the continuous discharge amps rate of your batterys too please
Fergin
#5 Posted : 15 December 2018 23:28:42
Not sure what that means?
#6 Posted : 15 December 2018 23:33:01
Do you have a link to the battery you bought so we can check it’s full spec/Amperage?
#7 Posted : 15 December 2018 23:35:49
The battery spec should have been provided by your battery vendor I have given an example below, the countinuos discharge rate is in bold-
Samsung 30Q 18650 3000mAh 15A -Button Top Battery - INR18650-30Q
Specifications:
Model: INR18650-30Q
Style: Button Top
Chemistry: INR
Nominal Capacity: 3000mAh
Continuous Discharge Rating: 15A
Pulse Discharge Rating: 25A
Nominal Voltage: 3.6V
Protected: No
Rechargeable: Yes
Approximate Dimensions: 18.42mm x 66.64mm (+1.80mm vs flat top version)
Approximate Weight: 48.5g
Fergin
#8 Posted : 15 December 2018 23:36:18
semaj
#9 Posted : 16 December 2018 00:21:10
ultrafire - say no more. bin em, buy proper batteries. brc is not a brand, it is the chemical make up of the battery. they are simply not powerful enough. plus ultrafire and trust fire are proven to be the worst on the market, they give false specs - especially the capacity, are often under powered cells re wrapped, and have even been proven to be a much smaller battery inside a metal tube. avoid ebay purchases at all costs.
realistically, would you really buy a high power battery from dodgey dave down the market? or would you source them from a reputable supplier with genuine credentials? even feedback on ebay can be faked.
Building:
Complete:
Fergin
#10 Posted : 16 December 2018 00:25:34
Whilst I see your point about the batteries, why would all of the other functions work, patrol mode for instance if it was a battery issue?
Fergin
semaj
#11 Posted : 16 December 2018 00:39:06
trust me. they are likely no where near 3600mah as stated (unless powering at lower than 350mA, which is what they test to get the capacity, not 1A+), they will likely be rated less than 1A discharge rate (there is no mention on the ad of the discharge rate), and there is no 18650 cell in existence that has a life of 1000 cycles. some of the best on the market produced by samsung, lg and sanyo only have a life cycle of around 500 charges. it also appears from the images in the ad that they are protected cells which would cause the most problems, hard to say for sure as again its not mentioned in the ad.
also here is some information from ultrafire themselves they do not make a 3600mah cell! https://www.ultrafire.co...-fire-18650-battery-a79
leads me to believe they are in fact fakes. the article linked above is directly from ultrafire website.
Building:
Complete:
#12 Posted : 16 December 2018 00:54:49
It’s widely known that a lot of Ultrafire batts are fakes and even dangerous, That’s not to say your’s are, but it is a possibility, especially if not purchased from a reputable seller. It’s a bit of a dilemma to swop or not.
Fergin
#13 Posted : 16 December 2018 12:13:49
Hi
I've ordered some Samsung ones as recommended in other posts,
As stated all other functions worked, including leg motors, ill repost once I have tried Samsung batteries
Thanks
Fergin
semaj
#14 Posted : 16 December 2018 13:06:25
Another suggestion, as i have seen a few people on facebook and a youtubeer having problems, all different, but all fixed the same way - check EVERY plug socket. The mcu, the sensor board, all the plugs in the dome etc are fully connected. One user was having a few different intermittent problems, all caused by 1 plug that was only partially connected.
Building:
Complete:
This page was generated in 0.186 seconds.
