R2 D2 does not self test, LED stuck on red Options
NeoFuture
#1 Posted : 15 December 2018 21:35:43
Rank: Beginner Level 3
Power on, batteries all charged, turning on he jolts forward, he head does not turn, and he does not change his LED from red, he does from time to time make noises,
first 4 buttons on the front make the same sound but perform no action,
Can anyone help ?
#2 Posted : 15 December 2018 21:40:57
Double check all you labels are correct and that all the plugs are in the correct sockets and seated properly.
Can you also provide the full spec of the batterys your using please.
PeterP
#3 Posted : 15 December 2018 22:02:55
This particular issue seems to becoming a bit of common problem as posted on other threads but post your battery specs first
NeoFuture
#4 Posted : 15 December 2018 22:11:31
OK got a bit further, disconnected the power pack from the MCU, reconnected and now I got the head moving but it rather violently spins one way, then the other, then settles about a 1/4 rotation, not as I was expecting, but its getting past the post red now, also the head does not rotate when in "patrol mode" I don't have an android device to test app control, but the head does not seem right, the battiest are Samsung 30q's
PeterP
#5 Posted : 15 December 2018 22:16:26
Batteries look ok, but you have to recheck all your connections and look for any bent pins if all's ok you may have to change the MCU!!!
NeoFuture
#6 Posted : 15 December 2018 22:18:44
rechecked all connectors all seated correctly, all the right way round, no bent pins...
PeterP
#7 Posted : 15 December 2018 22:23:56
It is possible you may have a bad connection somewhere?
NeoFuture
#8 Posted : 15 December 2018 22:29:24
no checked them all...
please see the video below
https://www.youtube.com/...OJ4&feature=youtu.be
PeterP
#9 Posted : 15 December 2018 22:32:45
Have you checked the head limiting switches on the back are working and connected the right way round
NeoFuture
#10 Posted : 15 December 2018 22:33:00
Also LED does not show Charge indication, I think I have a faulty MCU
PeterP
#11 Posted : 15 December 2018 22:35:24
Sounds very likely you may have to reorder issue 94
#12 Posted : 15 December 2018 22:37:39
From looking at your video the limit switches look to be not working correctly the head is just banging into the buffer and you say that after reconecting the battery box more things started to work.
You need to do a complete check of all your connections thsi includes all head and body connections and also to double check that they are labeled correctly. A complete check will take around 2 hours to do unfortunatly.
NeoFuture
#13 Posted : 15 December 2018 22:41:39
I will do a complete strip and check, but the fact that the head is rotating so quickly and not like other videos, where the head rotates more smoothly, would point that the motor control is also not working properly I would assume...
#14 Posted : 15 December 2018 22:46:48
If after a recheck of all conections labels and he is still acting in the same way we can then get onto replacement parts as I am not in front of your R2 I need to eliminate things one by one by asking.
NeoFuture
#15 Posted : 15 December 2018 23:34:07
Understand, and im willing to try anything, i have checked all cables in the body and head, have stripped down and traced back
below is a video with the head partial removed so I can block the sensors to check they are working too
https://www.youtube.com/watch?v=h9DVV8_ZZ0o
NeoFuture
#16 Posted : 15 December 2018 23:36:23
Photos attached
PeterP
#17 Posted : 17 December 2018 18:42:28
And if replacing the MCU doesn't fix it then the maybe replacing the Orange Pi microcomputer in the dome might? i've order that as well....Huh
#18 Posted : 17 December 2018 20:03:35
Please can you not to request Free replacements in advance of actually being needed as It could mean that another customer may not then be able to be sent a replacement they actually need should the issue go out of stock.
Free replacements are for items that actually need to be replaced rather than on a “just in case” basis
Thank you for your support,
PeterP
#19 Posted : 17 December 2018 20:04:49
Oops sorry Huh
semaj
#20 Posted : 18 December 2018 00:08:47
i know you mentioned that you have checked all your cables etc, but hear me out here;
someone on facebook noticed that one of the images in issue 97 shows one of the plugs actually back to front in the socket! so shows how easily a mistake can be made. double check you haven't inadvertently put a plug in a socket the wrong way around - they have tabs on the sides of the male plugs that line up with slots in the female socket.
i know it may sound like sucking eggs, but worth checking!
Building:
Complete:
