Memnoch Options
Memnoch
#1 Posted : 15 December 2018 20:15:03
Rank: Newbie
Finished build, went through battery activation. The R2D2 does not work at all. The side panel on the left lights up when I press the power button but I get nothing else.
Nice.
Anyone any ideas as I am not very happy at the cost spent for a non working build ?
Below is an image of what I mean.
Memnoch attached the following image(s):
#2 Posted : 15 December 2018 20:27:24
The side panel should only light up when the app is used, it stays off during start up and manual mode.
Firstly can you provide the spec and what batterys your using in R2 then can you double check all your cables are labeled and inserted correctly in there sockets.
PhilC
#3 Posted : 15 December 2018 20:27:42
yep same as mine , tell me do you also get the blue lights from the leg motors shining through the battery boxes ?
SOME MORNINGS IT JUST DOESN'T SEEM WORTH IT TO GNAW THROUGH THE LEATHER STRAPS
Memnoch
#4 Posted : 15 December 2018 20:32:08
Rank: Newbie
Yep, blue lights from leg motors also.
Batteries I am using are
Brand: Samsung SDI
Model: 30Q
Chemistry: INR
Nominal Capacity: 3000mAh
Nominal Voltage: 3.6V
Discharge: 15A Max Continuous
Positive: Button Top
Protected: No
Rechargeable: Yes
Dimensions: 18.23mm x 64.78mm
Weight: 46.1g
#5 Posted : 15 December 2018 21:08:01
Batterys look good have you charged them as per the instructions and used the suplied battery charger.
PeterP
#6 Posted : 15 December 2018 21:54:27
Sounds like you may of possible swapped LCD1 and RB connections in the head, but even if you have and you swap them around you may still end up with just the RED light on and nothing else happening!
Memnoch
#7 Posted : 16 December 2018 16:55:04
Rank: Newbie
Nope, I have checked and rechecked the connections.
PhilC
#8 Posted : 31 December 2018 11:30:20
Don't know if you have already sorted this issue, however, a few were having this issue on one of the facebook groups ... one poster found the issue (not me) and all now seems good .... the issue is the connector on the C-IN port on the board can easily be inserted the wrong way around , just check and turn 180 (the connector not you) job done !
This page was generated in 0.144 seconds.
