Back led Options
Bren
#1 Posted : 15 December 2018 16:33:06
My back led only shows yellow not showing green, even though the green was working on test during build. When I go to local wifi I never can get the green light to go on. Any thoughts guys.
#2 Posted : 15 December 2018 17:52:15
The yellow light on the back means you are in Direct WiFi, green light denotes you are in local WiFi. The different colours are so you know what mode you are in. To change it from direct to local press button 5. Just check that you are in the local mode and not direct.
Bren
#3 Posted : 15 December 2018 18:10:39
It lights yellow when IAM in direct wifi but when I go to local wifi I get no green light.
#4 Posted : 15 December 2018 18:23:07
Re-test the rear LED like you did in the test if it all works ok then recheck all your connections are good and retry.
Bren
#5 Posted : 15 December 2018 18:46:47
Already checked that yesterday sorry I shudder of mentioned that.
#6 Posted : 15 December 2018 19:30:29
Check the head circuit board for cracks and then check the connections from the board to the main board.
Bren
#7 Posted : 15 December 2018 21:31:38
Checked all connections no probs power going to all, no cracks in any of the boards.
#8 Posted : 15 December 2018 21:35:36
Could you check that the micro switches on R2's front panel are all working correctly.You should get a small click when pressed.
Bren
#9 Posted : 15 December 2018 21:39:40
Yes they are all working I checked them yesterday.
Bren
#10 Posted : 15 December 2018 21:41:35
I also removed the back led today to double check for the green light as re the test during the build and it showed up green. TBH I don't know what's causing this.
#11 Posted : 15 December 2018 21:51:49
There is a bad connection somewhere have you checked the pins are all straight in the sockets from the two cables that go from the head to the body sockets.
Bren
#12 Posted : 15 December 2018 21:56:54
Yeah that was the 2nd thing I checked tbh. Deffinatly a bad contact somewhere that's for sure. Time for R2D2 to have his 2nd operation 😂😂
#13 Posted : 15 December 2018 22:06:54
Make sure all the wires are seated correctly in the connectors too as this could be a cause of a bad connection.
Bren
#14 Posted : 15 December 2018 22:30:12
I will indeed thank you for your help. Other than this he is working great really happy with the little fella.
#15 Posted : 15 December 2018 22:42:06
Your welcome Bren, nice to have a thank you too and much appreciated. Please dont hesitate to ask again if you are still having problems with the little tyke.
Bren
#16 Posted : 15 December 2018 23:34:27
No problem thank you again he is all sorted it was one of the wires was the slightest bit loose and not making correct contact all gud now just putting his back on as I write this.
Thanks again. It's all bells and whistles from here 😂😂
#17 Posted : 15 December 2018 23:41:21
BigGrin Great stuff Bren and glad to be of help.
Now the adventure beginsDrool Drool Drool Drool BigGrin Cool
Bren
#18 Posted : 16 December 2018 00:09:06
Indeed now will it be camper van T600 Terminator or the X Wing mmmm decisions decisions 😊😂
#19 Posted : 16 December 2018 01:04:02
BigGrin If your into ships the 'Standart' could be an option tooCool
#20 Posted : 16 December 2018 01:09:15
Great to hear you've now got the little fella up and working Bren and am sure you'll have lots of fun with him.... well done...Cool Cool
This page was generated in 0.121 seconds.
