Button 5 Options
Michaeljf1980
#1 Posted : 14 December 2018 14:20:50
Rank: Beginner Level 3
Hi, what does it mean If button 5 isn’t doing anything on R2, but button 4 is working fine
#2 Posted : 14 December 2018 14:31:05
It sounds like you may have a faulty switch., disassemble the switch assembly, check to see if the faulty switch clicks then re-test and replace switch board if need be.
#3 Posted : 14 December 2018 18:26:09
Button 5 switches between local WiFi and direct WiFi, switching between each one. Have you setup both options?
If you have just set up one WiFi option then it wouldn’t be able to switch.
Michaeljf1980
#4 Posted : 14 December 2018 18:31:11
I haven’t set up either of them yet, as both of them won’t connect, see my other topic I’ve just started
